petsc I/O
Matt Funk
mafunk at nmsu.edu
Fri Sep 15 11:21:39 CDT 2006
thanks for the answers first of all. I have another question though ... :)
Say, i want to print a specific element from a PETSc global vector. Is there a
function (PetscSunchFPrintF does not do this i believe) to which i simply
pass the file handle, communicator, the vector and the element and it writes
the value to the file?
thanks
mat
On Wednesday 13 September 2006 17:13, Berend van Wachem wrote:
> Hi Matt,
> > i need to read in an input file. So to open my file i use PETSCFOpen
> > which works fine. But then my problems begin ... :)
> > I guess i need to tell only the first proc in the communicator to fscan.
> > But is there a PETSC function that returns me the processor id?
> > And when i read the parameters in on the first proc i need to broadcast
> > them to the other procs. Does PETSC have anything for this?
> For both issues you can use standard MPI:
> to get the processor ID:
> ierr=MPI_Comm_rank(MPI_Comm Communicator,int *rank);
> to broadcast information:
> ierr=MPI_Bcast ( void *buffer, int count, MPI_Datatype datatype, int
> root, MPI_Comm comm )
> If possible, I would recommend you to use the PetscViewer interface for
> your IO handling; it is very easy.
> Good luck,
> Berend.
