petsc I/O
Berend van Wachem berend at chalmers.se
Wed Sep 13 18:13:48 CDT 2006
Hi Matt,
> i need to read in an input file. So to open my file i use PETSCFOpen which
> works fine. But then my problems begin ... :)
> I guess i need to tell only the first proc in the communicator to fscan. But
> is there a PETSC function that returns me the processor id?
> And when i read the parameters in on the first proc i need to broadcast them
> to the other procs. Does PETSC have anything for this?
For both issues you can use standard MPI:
to get the processor ID:
ierr=MPI_Comm_rank(MPI_Comm Communicator,int *rank);
to broadcast information:
ierr=MPI_Bcast ( void *buffer, int count, MPI_Datatype datatype, int
root,  MPI_Comm comm )
If possible, I would recommend you to use the PetscViewer interface for
your IO handling; it is very easy.
Good luck,
Berend.
