FW: Spooles Cholesky problem
Fri Sep 1 07:05:15 CDT 2006
Hi
> When using the Spooles Cholesky solver I am getting the error:
> 0:[0]PETSC ERROR: MatSetValues_SeqSBAIJ() line 792 in
> src/mat/impls/sbaij/seq/sbaij.c 0:[0]PETSC ERROR: ! 0:[0]PETSC ERROR:
> Lower
> triangular value cannot be set for sbaij format. Ignoring these values,
> run
> with -mat_ignore_lower_triangular or call
> MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGULAR)!
> 0:[0]PETSC ERROR: MatSetValues() line 702 in src/mat/interface/matrix.c
> When I attempt to call MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGULAR,ierr)
> via the Fortran interface, I get the compilation error that entity
> mat_ignore_lower_triangular has undefined type. Can you tell me if this
> option is supported via the Fortran interface?
This is certainly there in the development version, and we plan to release
in a week
or so. However, a very easy fix is to update the list of enums at the top of
   include/finclude/petscmat.h
with the enum from
   include/petscmat.h
     Matt
Note that using runtime option  -mat_ignore_lower_triangular works, but I
> would prefer to set this option in my code using the MatSetOption()
> routine.
> Regards
> Stephen
> _______________________________________________________________________________
> The information in this email and in any attachment(s) is commercial in
> confidence. If you are not the named addressee(s) or if you receive this
> email in error then any distribution, copying or use of this communication
> or the information in it is strictly prohibited.  Please notify us
> immediately by email at admin.internet(at)awe.co.uk, and then delete this
> message from your computer.  While attachments are virus checked, AWE plc
> does not accept any liability in respect of any virus which is not detected.
> AWE Plc
> Registered in England and Wales
> Registration No 02763902
> AWE, Aldermaston, Reading, RG7 4PR
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060901/32882b8e/attachment.htm>
