FW: Spooles Cholesky problem
Stephen R Ball
Stephen.R.Ball at awe.co.uk
Fri Sep 1 04:08:18 CDT 2006
Hi
I am sending the message below again as no one has replied yet.
Regards
Stephen
Hi
When using the Spooles Cholesky solver I am getting the error:
0:[0]PETSC ERROR: MatSetValues_SeqSBAIJ() line 792 in
src/mat/impls/sbaij/seq/sbaij.c 0:[0]PETSC ERROR: ! 0:[0]PETSC ERROR: Lower
triangular value cannot be set for sbaij format. Ignoring these values, run
with -mat_ignore_lower_triangular or call
MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGULAR)!
0:[0]PETSC ERROR: MatSetValues() line 702 in src/mat/interface/matrix.c
When I attempt to call MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGULAR,ierr)
via the Fortran interface, I get the compilation error that entity
mat_ignore_lower_triangular has undefined type. Can you tell me if this
option is supported via the Fortran interface?
Note that using runtime option -mat_ignore_lower_triangular works, but I
would prefer to set this option in my code using the MatSetOption() routine.
Regards
Stephen
_______________________________________________________________________________
The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited. Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer. While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected.
AWE Plc
Registered in England and Wales
Registration No 02763902
AWE, Aldermaston, Reading, RG7 4PR
