about runtime lib conflict
Sun Oct 29 01:42:39 CDT 2006
On Sun, 29 Oct 2006, Yixun Liu wrote:
> Hi,
> I use PETSC with other libs, but they use different runtime lib.
I don't understand this statement.
> I hope to config PETSC with Debug multithread dll runtime lib. How
> to do it?
1. Build PETSc libraries with the default configure options
 [The defaults enable  Debug, multithread, dll options for MS compilers.]
2. Build the libraries
3. Verify 'make test' works
4. If you need to use these libraries from MS Project File, follow
instructions in the section 'Project Files' at
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
