divergence?
Matthew Knepley
knepley at gmail.com
Mon Mar 20 14:08:48 CST 2006
You can use -pc_type lu -ksp_type preonly. There are also third-party
packages like MUMPS which you can install automatically with configure.
Matt
On 3/20/06, buket at be.itu.edu.tr <buket at be.itu.edu.tr> wrote:
> Hello again,
> I want to compare the iterative methods with direct methods in terms of
> time.
> What functions can I use for direct solution?
> Best Regards,
> Buket Benek
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060320/75549a41/attachment.htm>
