***LOOPING MAIL***  PetscInitialize problem?
    ziemer at lncc.br
    ziemer at lncc.br
    Wed Mar 15 08:26:46 CST 2006
Yes, I have already tried to include the file mpif.h and them the compiler
indicated that there was some variables that were already had been declared
(doubled declaration).
Thank you very much.
Paulo Ziemer
Quoting Barry Smith <bsmith at mcs.anl.gov>:
>    Are you sure that mpif.h is actually being included
> by include/finclude/petsc.h?
>     Barry
> On Tue, 14 Mar 2006, ziemer at lncc.br wrote:
> > This is part of the source code where the problem happens:
> > Thank you for your patience.
> > PROGRAM Premain
> > C     ------------------------------------------------------------------
> > !     Use ModuloLectura
> >      IMPLICIT REAL*8 (A-H,O-Z)
> > !     Parallel begin
> > !     petsc include files
> > #include "include/finclude/petsc.h"
> > !     Parallel end
> >      Logical Sym, NonLinearProblem,Iterative
> >      INTEGER ERR_ALLOC
> >      Parameter (Lch=16)
> >      Character Str*120
> >      double precision noMPI_Wtime
> > C
> > !     INTERFACE ReadMat
> > !     MODULE PROCEDURE ReadMat
> > !     END INTERFACE
> > !     INTERFACE ReadCoupling
> > !     MODULE PROCEDURE ReadCoupling
> > !     END INTERFACE
> > !     INTERFACE Dimen
> > !     MODULE PROCEDURE Dimen
> > !     END INTERFACE
> > C
> >      Allocatable X         (:)
> >      Allocatable Ie__Param (:)
> >      Allocatable Ie_JParam (:)
> >      Allocatable Param     (:)
> > !     Parallel begin
> >      call PetscInitialize (PETSC_NULL_CHARACTER, iError)
> >      if (iError.ne.0) then
> >         Write (6,*) "Can't initialize PETSC"
> >         Stop
> >      End if
> > !     Ask total number of proccesses
> > !     PROBLEM BEGINS IN THE NEXT FUNCTION - MPI_COMM_WORLD IS NOT SET!!
> >      call MPI_Comm_size (MPI_COMM_WORLD, iSize, iError)
> > !     ID of this proccess
> >      call MPI_Comm_rank (MPI_COMM_WORLD, iRank, iError)
> > Quoting Satish Balay <balay at mcs.anl.gov>:
> >> You should be able to use either MPI_COMM_WORLD or PETSC_COMM_WORLD or
> >> any other communicator. There must be something else wrong in your
> >> code. Can't comment without looking at the code.
> >> Satish
> >> On Mon, 13 Mar 2006, ziemer at lncc.br wrote:
> >>> Hi,
> >>> The Petsc installation examples run ok.
> >>> The strange thing is if I change the parameter MPI_COMM_WORLD of the
> >> function
> >>> MPI_Comm_size() to PTESC_COMM_WORLD this function works, but at same time
> >> this
> >>> same strategy does not work with the MPI_Bcast() function.
> >>> Thank you very much for your nice help.
> >>> Paulo Ziemer.
> >>>> According to the error message - the communicator is invalid.  You
> >>>> might want to check that..
> >>>> You should be able to call MPI_Comm_size() after PetscInitialize()
> >>>> Check src/sys/examples/tutorials/ex1.c for an example of this usage.
> >>>> BTW: Do PETSc examples run fine with your install?
> >>>> Satish
> >>>>> Hello,
> >>>>> I would be very glad if someone could give me some direction:
> >>>>> After the MPI_Comm_size function is called, I got this error:
> >>>>> aborting job:
> >>>>> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> >>>>> MPI_Comm_size(110): MPI_Comm_size(comm=0x1, size=0xbfffdf78) failed
> >>>>> MPI_Comm_size(69): Invalid communicator
> >>>>> It seems that the MPI environment is not being correctly created by the
> >>>> function
> >>>>> PetscInitialize.
> >>>>> Does anyone have any idea?
> >>>>> Best Regards.
> >>>>> This message was sent using IMP, the Internet Messaging Program.
