***LOOPING MAIL*** PetscInitialize problem?
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 14 14:25:42 CST 2006
Are you sure that mpif.h is actually being included
by include/finclude/petsc.h?
Barry
On Tue, 14 Mar 2006, ziemer at lncc.br wrote:
> This is part of the source code where the problem happens:
> Thank you for your patience.
> PROGRAM Premain
> C ------------------------------------------------------------------
> ! Use ModuloLectura
> IMPLICIT REAL*8 (A-H,O-Z)
> ! Parallel begin
> ! petsc include files
> #include "include/finclude/petsc.h"
> ! Parallel end
> Logical Sym, NonLinearProblem,Iterative
> INTEGER ERR_ALLOC
> Parameter (Lch=16)
> Character Str*120
> double precision noMPI_Wtime
> C
> ! INTERFACE ReadMat
> ! MODULE PROCEDURE ReadMat
> ! END INTERFACE
> ! INTERFACE ReadCoupling
> ! MODULE PROCEDURE ReadCoupling
> ! END INTERFACE
> ! INTERFACE Dimen
> ! MODULE PROCEDURE Dimen
> ! END INTERFACE
> C
> Allocatable X (:)
> Allocatable Ie__Param (:)
> Allocatable Ie_JParam (:)
> Allocatable Param (:)
> ! Parallel begin
> call PetscInitialize (PETSC_NULL_CHARACTER, iError)
> if (iError.ne.0) then
> Write (6,*) "Can't initialize PETSC"
> Stop
> End if
> ! Ask total number of proccesses
> ! PROBLEM BEGINS IN THE NEXT FUNCTION - MPI_COMM_WORLD IS NOT SET!!
> call MPI_Comm_size (MPI_COMM_WORLD, iSize, iError)
> ! ID of this proccess
> call MPI_Comm_rank (MPI_COMM_WORLD, iRank, iError)
> Quoting Satish Balay <balay at mcs.anl.gov>:
>> You should be able to use either MPI_COMM_WORLD or PETSC_COMM_WORLD or
>> any other communicator. There must be something else wrong in your
>> code. Can't comment without looking at the code.
>> Satish
>> On Mon, 13 Mar 2006, ziemer at lncc.br wrote:
>>> Hi,
>>> The Petsc installation examples run ok.
>>> The strange thing is if I change the parameter MPI_COMM_WORLD of the
>> function
>>> MPI_Comm_size() to PTESC_COMM_WORLD this function works, but at same time
>> this
>>> same strategy does not work with the MPI_Bcast() function.
>>> Thank you very much for your nice help.
>>> Paulo Ziemer.
>>>> According to the error message - the communicator is invalid. You
>>>> might want to check that..
>>>> You should be able to call MPI_Comm_size() after PetscInitialize()
>>>> Check src/sys/examples/tutorials/ex1.c for an example of this usage.
>>>> BTW: Do PETSc examples run fine with your install?
>>>> Satish
>>>>> Hello,
>>>>> I would be very glad if someone could give me some direction:
>>>>> After the MPI_Comm_size function is called, I got this error:
>>>>> aborting job:
>>>>> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
>>>>> MPI_Comm_size(110): MPI_Comm_size(comm=0x1, size=0xbfffdf78) failed
>>>>> MPI_Comm_size(69): Invalid communicator
>>>>> It seems that the MPI environment is not being correctly created by the
>>>> function
>>>>> PetscInitialize.
>>>>> Does anyone have any idea?
>>>>> Best Regards.
>>>>> This message was sent using IMP, the Internet Messaging Program.
