Using External packages with PETSC
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Jun 26 09:24:40 CDT 2006
   Laslo,
    You can do this; but for some reason config/configue.py rejected that
directory. You can look in configure.log or send it to petsc-maint at mcs.anl.gov
to see why it was rejected. (Often it is because it was compiled with a
different compiler or different MPI or compiler options).
   Barry
On Mon, 26 Jun 2006, Laslo Tibor Diosady wrote:
> I'm trying to use ParMetis with PETSc but I already have the ParMetis
> distribution. As opposed to using the option
> --download-parmetis=1 is it possible to specify the location of the parmetis
> directory in the same manner as the mpi directory.
> In other words can I do something like
> --with-parmetis-dir=/usr/local/ParMetis-3.1/
> I tried this particular line but I ran the configure script I got the error
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> --with-parmetis-dir=/usr/local/ParMetis-3.1 did not work
> Is there another way to specify the parmetis directory or should I just use
> --download-parmetis=1?
> Thanks,
> Laslo
