Using External packages with PETSC
Laslo Tibor Diosady diosady at MIT.EDU
Mon Jun 26 09:21:40 CDT 2006
I'm trying to use ParMetis with PETSc but I already have the ParMetis
distribution. As opposed to using the option
--download-parmetis=1 is it possible to specify the location of the
parmetis directory in the same manner as the mpi directory.
In other words can I do something like
--with-parmetis-dir=/usr/local/ParMetis-3.1/
I tried this particular line but I ran the configure script I got the
error
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
--with-parmetis-dir=/usr/local/ParMetis-3.1 did not work
Is there another way to specify the parmetis directory or should I just
use --download-parmetis=1?
Laslo
