about ghosted vectors and there local representation
Tue Jun 20 06:32:52 CDT 2006
> I now expect the vector to be in the local form. That means that the
> positions
> that I created as ghost points are filled with the solution corresponding
> to
> the global solution. I expect that they are inserted in the position in my
> local vector corresponding to there corresponding global position.
Not sure what you mean here.  The local form is the same as the global
vector
in the owned spots, and then has the ghost points at the end.
    Matt
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060620/9c012af8/attachment.htm>
