about ghosted vectors and there local representation
    Thomas Geenen
    geenen at gmail.com
    Tue Jun 20 05:31:50 CDT 2006
Dear Petsc users,
I think that I do not use the ghosted vector concept in the right way.
I create a vector with
ierr = VecCreateGhost(PETSC_COMM_WORLD, nc,
                            		 PETSC_DECIDE, nghosts, ghosts, &x);
The entries in ghost contain the global vector positions that I want to have
available locally.
I have a local representation so i apply (after having constructed the mapping
of course)
ierr = VecSetLocalToGlobalMapping(x,ltog);
I now insert the values
ierr = VecSetValuesLocal(x, nc, indx, x_values, INSERT_VALUES);
VecAssemblyBegin(x);
VecAssemblyEnd(x);
I am now under the assumption that petsc divided the vector entries among
processes according to his global representation of the vector.
I solve my system of equations
KSPSolve(ksp,b,x);
afterwards i do
ierr = KSPGetSolution(ksp, &x);
ierr = VecGhostUpdateBegin(x,INSERT_VALUES,SCATTER_FORWARD);
ierr = VecGhostUpdateEnd(x,INSERT_VALUES,SCATTER_FORWARD);
ierr = VecGhostGetLocalForm(x, &lx);
I now expect the vector to be in the local form. That means that the positions
that I created as ghost points are filled with the solution corresponding to
the global solution. I expect that they are inserted in the position in my
local vector corresponding to there corresponding global position.
apparently this is not what happens.
a small example
2 cpu's
each cpu contains 3 vector entries however there is an overlap of 1
on cpu 1 the vector contains points (1, 2, 3)
on cpu 2 the vector contains points (3, 4, 5)
I make position 1 on cpu 2 a ghost points with nghost=1 ghosts(3)
after solving and restoring I expect vector lx to contain the solution as (3,
4, 5)
I hope I have explained my misunderstanding of the underlying concept clear
enough
thanks for your help
Thomas Geenen
