Matrix input file format
Evrim Dizemen
gudik at ae.metu.edu.tr
Thu Jun 15 08:55:19 CDT 2006
Dear Randall,
I guess i began to understand the consepts but there is still a missing
point that i do not know when and how we define Istart and Iend. I'll be
glade if you can send me the pre_op3d routine so i can see the algorithm
which is a black box for me now.
Thanks a lot
EVRIM
Randall Mackie wrote:
> Hi Evrim,
> It's quite easy to modify your Fortran code to do what you want. I
> thought
> I had written it all out before, but I'll try again. There are many ways
> to do this, but I'll start with the easiest, at least if you're going to
> just modify your current sequential code.
> Let's say that your matrix has np global rows. Then
> call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,np,b,ierr)
> call VecDuplicate(b,xsol,ierr)
> call VecGetLocalSize(b,mloc,ierr)
> call VecGetOwnershipRange(b,Istart,Iend,ierr)
> do i=Istart+1,Iend
> loc(i)=i-1
> end do
> These statements create parallel vectors for the solution (xsol) and
> the right hand side (b). The vector loc(i)is used to set values in the
> vectors later.
> Then
> ! Create the linear solver context
> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> ! Create the scatter context for getting results back to
> ! each node.
> call VecScatterCreateToAll(xsol,xToLocalAll,xseq,ierr)
> ! Create the matrix that defines the linear system, Ax = b,
> ! for the EM problem.
> call pre_op3d(l,m,nzn,Istart,Iend,ijkhx,ijkhy,ijkhz,d_nnz,o_nnz)
> call MatCreateMPIAIJ(PETSC_COMM_WORLD,mloc,mloc,np,np,
> . PETSC_NULL_INTEGER, d_nnz, PETSC_NULL_INTEGER,
> . o_nnz,A,ierr)
> call set_op3d(A,l,m,nzn,period,resist,x,y,z,Istart,Iend,
> . ijkhx,ijkhy,ijkhz)
> The subroutine pre_op3d is an important routine and it figures out
> how to pre-allocate space for your parallel matrix. This will be
> the difference between near-instanteous assembly and 2.5 hours that
> you experienced. Basically, it just computes the global column numbers,
> and figures out if they are between Istart and Iend. I can send you
> my subroutine if you'd like.
> The subroutine set_op3d.F actually assembles the parallel matrix and
> goes like this:
> jj=0
> do i=1,l
> do k=2,n
> do j=2,m
> jj=jj+1
> row = jj-1
> IF (jj >= Istart+1 .and. jj <= Iend) THEN
> compute elements...
> call MatSetValues(A,i1,row,ic,col,v,INSERT_VALUES,
> . ierr)
> END IF
> end do
> end do
> end do
> At the end,
> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> Again, because you compute the pre-allocation, this is near-instanteous,
> even for large models (larger than you're using).
> Once you do that, you're golden:
> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> etc.
> Randy M.
> San Francisco
> Evrim Dizemen wrote:
>> Hi all,
>> Again thanks for your comments. I guess i can not define the problem
>> correctly. I have a sequantial fortran code giving me the global
>> matrix of 200000x200000. The code writes the matrix in a binary file
>> at little endian mode (i can write only the nonzero terms or the
>> entire matrix). I tried to change the binary mode to big endian and
>> read the global matrix by a c program as in the example
>> /src/mat/example/tests/ex31.c. However the program reads binary file
>> wrong and gives the following error message but the true value of
>> no-nonzero in the binary file is 6 (for the test case 3x3 matrix) :
>> reading matrix in binary from matrix.dat ...
>> Petsc Release Version 2.3.1, Patch 13, Wed May 10 11:08:35 CDT 2006
>> BK revision: balay at asterix.mcs.anl.gov|ChangeSet|20060510160640|13832
>> See docs/changes/index.html for recent updates.
>> See docs/faq.html for hints about trouble shooting.
>> See docs/index.html for manual pages.
>> ./ex31 on a linux named akbaba.ae.metu.edu.tr by evrim Thu Jun 15
>> 09:26:36 2006
>> Libraries linked from /home/evrim/petsc-2.3.1-p13/lib/linux
>> Configure run at Tue May 30 10:26:48 2006
>> Configure options --with-scalar-type=complex --with-shared=0
>> [0]PETSC ERROR: MatLoad_SeqAIJ() line 3055 in
>> src/mat/impls/aij/seq/aij.c
>> [0]PETSC ERROR: Read from file failed!
>> [0]PETSC ERROR: Inconsistant matrix data in file. no-nonzeros =
>> 100663296, sum-row-lengths = 234300
>> [0]PETSC ERROR: MatLoad() line 149 in src/mat/utils/matio.c
>> [0]PETSC ERROR: main() line 37 in src/mat/examples/tests/ex31.c
>> I want to send the global matrix at once to Petsc by a written input
>> file (as i'm working on now) or by sending the matrix array from my
>> fortran code and then partition it and solve iteratively. After the
>> solution i also want to get the solution vector back to my fortran
>> code. As i told in the previous mails i tried to send the matrix
>> array to Petsc and used MatSetValues as reading one value at time in
>> a do loop but it took about 2,5 hours to read the global matrix.
>> Additionally i tried to read a row at a time but can not figure out
>> a algorithm for this. Hence i do not prefer to create the matrix
>> again in Petsc by MatSetValues.
>> Aside i figured out that the binary files written in fortran and c
>> are completely different from each other (fortran adds the size of
>> the characters to the beginning and end of each character) so i wrote
>> a c interface code to get the matrix array from the fortran code and
>> write it to a binary file in c format. By this code i avoided from
>> the additional information in the binary file but i still have the
>> endianness problem.
>> I know that i asked so much but since i'm a rookie in parallel
>> programming, c language and library using i really need your comments
>> on my problem. Sorry for this long mail and thanks a lot for your
>> kind effort on guiding me.
>> Thanks
>> EVRIM
