Matrix input file format
Randall Mackie randy at geosystem.us
Thu Jun 15 08:03:40 CDT 2006
Hi Evrim,
It's quite easy to modify your Fortran code to do what you want. I thought
I had written it all out before, but I'll try again. There are many ways
to do this, but I'll start with the easiest, at least if you're going to
just modify your current sequential code.
Let's say that your matrix has np global rows. Then
       call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,np,b,ierr)
       call VecDuplicate(b,xsol,ierr)
       call VecGetLocalSize(b,mloc,ierr)
       call VecGetOwnershipRange(b,Istart,Iend,ierr)
       do i=Istart+1,Iend
         loc(i)=i-1
       end do
These statements create parallel vectors for the solution (xsol) and
the right hand side (b). The vector loc(i)is used to set values in the
vectors later.
Then
!         Create the linear solver context
       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
!         Create the scatter context for getting results back to
!         each node.
       call VecScatterCreateToAll(xsol,xToLocalAll,xseq,ierr)
!     Create the matrix that defines the linear system, Ax = b,
!     for the EM problem.
       call pre_op3d(l,m,nzn,Istart,Iend,ijkhx,ijkhy,ijkhz,d_nnz,o_nnz)
       call MatCreateMPIAIJ(PETSC_COMM_WORLD,mloc,mloc,np,np,
      .     PETSC_NULL_INTEGER, d_nnz, PETSC_NULL_INTEGER,
      .     o_nnz,A,ierr)
       call set_op3d(A,l,m,nzn,period,resist,x,y,z,Istart,Iend,
      .           ijkhx,ijkhy,ijkhz)
The subroutine pre_op3d is an important routine and it figures out
how to pre-allocate space for your parallel matrix. This will be
the difference between near-instanteous assembly and 2.5 hours that
you experienced. Basically, it just computes the global column numbers,
and figures out if they are between Istart and Iend. I can send you
my subroutine if you'd like.
The subroutine set_op3d.F actually assembles the parallel matrix and
goes like this:
       jj=0
       do i=1,l
         do k=2,n
           do j=2,m
             jj=jj+1
             row = jj-1
             IF (jj >= Istart+1 .and. jj <= Iend) THEN
	       compute elements...
               call MatSetValues(A,i1,row,ic,col,v,INSERT_VALUES,
      .             ierr)
             END IF
           end do
         end do
       end do
At the end,
       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
Again, because you compute the pre-allocation, this is near-instanteous,
even for large models (larger than you're using).
Once you do that, you're golden:
         call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
etc.
Randy M.
San Francisco
Evrim Dizemen wrote:
> Hi all,
> Again thanks for your comments. I guess i can not define the problem
> correctly. I have a sequantial fortran code giving me the global matrix
> of 200000x200000. The code writes the matrix in a binary file at little
> endian mode (i can write only the nonzero terms or the entire matrix). I
> tried to change the binary mode to big endian and read the global matrix
> by a c program as in the example /src/mat/example/tests/ex31.c. However
> the program reads binary file wrong and gives the following error
> message but the true value of no-nonzero in the binary file is 6 (for
> the test case 3x3 matrix) :
> reading matrix in binary from matrix.dat ...
> Petsc Release Version 2.3.1, Patch 13, Wed May 10 11:08:35 CDT 2006
> BK revision: balay at asterix.mcs.anl.gov|ChangeSet|20060510160640|13832
> See docs/changes/index.html for recent updates.
> See docs/faq.html for hints about trouble shooting.
> See docs/index.html for manual pages.
> ./ex31 on a linux named akbaba.ae.metu.edu.tr by evrim Thu Jun 15
> 09:26:36 2006
> Libraries linked from /home/evrim/petsc-2.3.1-p13/lib/linux
> Configure run at Tue May 30 10:26:48 2006
> Configure options --with-scalar-type=complex --with-shared=0
> [0]PETSC ERROR: MatLoad_SeqAIJ() line 3055 in src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: Read from file failed!
> [0]PETSC ERROR: Inconsistant matrix data in file. no-nonzeros =
> 100663296, sum-row-lengths = 234300
> [0]PETSC ERROR: MatLoad() line 149 in src/mat/utils/matio.c
> [0]PETSC ERROR: main() line 37 in src/mat/examples/tests/ex31.c
> I want to send the global matrix at once to Petsc by a written input
> file (as i'm working on now) or by sending the matrix array from my
> fortran code and then partition it and solve iteratively. After the
> solution i also want to get the solution vector back to my fortran code.
> As i told in the previous mails i tried to send the matrix array to
> Petsc and used MatSetValues as reading one value at time in a do loop
> but it took about 2,5 hours to read the global matrix. Additionally i
> tried to read a row at  a time but can not figure out a algorithm for
> this. Hence i do not prefer to create the matrix again in Petsc by
> MatSetValues.
> Aside i figured out that the binary files written in fortran and c are
> completely different from each other (fortran adds the size of the
> characters to the beginning and end of each character) so i wrote a c
> interface code to get the matrix array from the fortran code and write
> it to a binary file in c format. By this code i avoided from the
> additional information in the binary file but i still have the
> endianness problem.
> I know that i asked so much but since i'm a rookie in parallel
> programming, c language and library using i really need your comments on
> my problem. Sorry for this long mail and thanks a lot for your kind
> effort on guiding me.
> Thanks
> EVRIM
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
