Problems using external packages Spooles and Hypre with PETSc v2. 3.1
Stephen R Ball Stephen.R.Ball at awe.co.uk
Fri Jun 2 06:06:31 CDT 2006
Hi
I have been having (patch 9). I was not having these problems with
PETSc v2.3.0.
I am using Spooles downloaded from the PETSc ftp site and built into
PETSC_DIR/externalpackages. When solving a partcular problem I am getting
the error:
MatFactorNumeric_MPIAIJSpooles line 199
src/mat/impls/aij/mpi/spooles/mpispooles.c
MatLUFactorNumeric line 2200 src/mat/interface/matix.c
KSPSetUp line 183 src/ksp/ksp/interface/itfunc.c
KSPSolve line 305 src/ksp/ksp/interface/itfunc.c
The problem also occurs in serial.
I am using Hypre v1.10.0b downloaded from the LLNL site and built separatly
to PETSc. When I have been using Pilut and Parasails as either global
problem preconditioners of as sub preconditioners for ASM or BJACOBI, I have
been getting errors indicating that there could be a memory access out of
range. I suspect that there may be a memory overwrite or mismatch occuring
somewhere. Note that BOOMERAMG and EUCLID seem to work OK. Again these
problems were not apparent when I was using PETSc v2.3.0.
Have there been any significant changes in the PETSc source that handles
Spooles and Hypre between versions 2.3.0 and 2.3.1 that could be causing
these problems? I don't really want to go back to using PETSc v2.3.0 if I
can help it. I don't know if it makes any difference, but I am using the
Fortran interface to PETSc.
Hope you can help.
Regards
Stephen R. Ball
_______________________________________________________________________________
The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited.  Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer.  While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected.
AWE Plc
Registered in England and Wales
Registration No 02763902
AWE, Aldermaston, Reading, RG7 4PR
