building libraries
Matthew Knepley
knepley at gmail.com
Thu Jun 1 12:12:06 CDT 2006
I recommend reading the makefile section of the manual. Briefly, you should
at least use the bmake/common/variables makefile to get such things as
PETSC_INCLUDE correct (that is the problem here), if not use the targets in
bmake/common/rules. You could use our example makefiles as a guide.
Matt
On 6/1/06, Matt Funk <mafunk at nmsu.edu> wrote:
> Thanks for the replies,
> the whole mpicc is a little system specific. It build the libraries after
> all,
> so it's fine.
> However, now i got another question. I link the libraries into my program,
> and
> then in my top level code i include petscksp.h. When i try to compile it,
> it
> gives me the following error:
> In file included
> from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscis.h:7,
> from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscvec.h:9,
> from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscmat.h:6,
> from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscpc.h:6,
> from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscksp.h:6,
> from testNodePoisson.cpp:65:
> /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petsc.h:13:23:
> petscconf.h: No such file or directory
> The only include directory that i have specified is /include in the petsc
> root
> directory. I couldn't find petscconf.h anywhere, so i was wondering if
> somebody knows what i am doing wrong here.
> thanks
> mat
> On Wednesday 31 May 2006 16:08, Matthew Knepley wrote:
> > You can have PETSc install MPI using --download-mpich. You can make
> > sure that it does not use mpicc using --with-mpi-compilers=0.
> > Matt
> > On 5/31/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > > Hi,
> > > i need to build PETsC on s sycld machine. Basically i need to have MPI
> > > support
> > > in PetsC but i need to switch from using mpicc to gcc.
> > > I was wondering if someone could point to how i can do that. (Is there
> an
> > > option that i overlooked?)
> > > thanks
> > > mat
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060601/fd228ce4/attachment.htm>
