Help on installation of PETSC+prometheus on Cygwin
Letian Wang
letian.wang at ghiocel-tech.com
Tue Feb 21 09:57:52 CST 2006
Hello,
I had problems to install PETSc-2.3.1-p5 and Prometheus on my notebook under
Cygwin environment. Here are the options I used:
--with-blas-lapack-dir=$PETSC_DIR/externalpackages/fblaslapack/$PETSC_ARCH
--with-debugging=0
--with-mpi-dir=$HOME/mpich2-install
--download-parmetis=1
--download-prometheus=1
--download-spooles=1
--download-hypre=1
I could download Parmetis and it seemed the compiling was ok because I saw
files libparmetis.a and libmetis.a. However, PETSc complains the downloaded
Parmetis cannot be used. Attached is the configure.log file.
Any helps are greatly appreciated. Thanks.
Letian Wang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060221/8f2bfad2/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060221/8f2bfad2/attachment.obj>
