how to implement parallel integer optimization with petsc?
Matthew Knepley
knepley at mcs.anl.gov
Sat Feb 4 13:27:02 CST 2006
Tomasz Jankowski <tomjan at jay.au.poznan.pl> writes:
Unfortunately, AMPL does a lot of processing. It would be a big
job to translate this to PETSc.
Matt
>> PETSc basically offers parallel linear algebra and nonlinear solvers.
>> If you can phrase the algorithm in linear algebraic terms, then we can probably help.
> unfortunetly I can't (sorry I'm not mathematicst) but I can phrase my problem in AMPL language. please look at the two
> files which I have pasted at the end of this email. mate-selection.mod contain optimization model in AMPL. the second
> file mate-selection.dat contain the example data.
> Please forgive me my previous email with unclear description of my problem (its because of my english).once again I need
> to assert that I don't expect the full recipe for implementation of my problem with PETSc.
> I will realy appreciate if you give some sugesstion.
> Thank you for your reply
> tom
> (ps. if AMPL model is not good I provide my algorithm in algebraic terms)
> ---------mate-selection.mod----------------
> set BULLS;
> set COWS;
> param ebv {COWS,BULLS} >= 0;
> param cost {BULLS} > 0;
> param f {COWS,BULLS} >= 0;
> param l_cows > 0;
> var Pairs {COWS,BULLS} binary;
> maximize Total_Ebv:
> sum {i in COWS, j in BULLS} ebv[i,j] * Pairs[i,j];
> subject to Max_cows {i in COWS}: sum{j in BULLS} Pairs[i,j] = 1;
> subject to Max_bulls {j in BULLS}: sum{i in COWS} Pairs[i,j] <= 2;
> subject to F: (sum{i in COWS, j in BULLS} f[i,j] * Pairs[i,j])/l_cows <= 0.03;
> subject to Cost: sum{ i in COWS, j in BULLS} Pairs[i,j] * cost[j] <=500;
> -----------------mate-selection.dat---------------------
> data;
> set BULLS := male0 male1 male2 male3 male4;
> set COWS := female0 female1 female2;
> param ebv: male0 male1 male2 male3 male4:=
> female0 290 410 298 400 471
> female1 901 807 956 653 173
> female2 185 453 733 316 367
> param f: male0 male1 male2 male3 male4:=
> female0 0.076 0.048 0.068 0.064 0.064
> female1 0.078 0.057 0.035 0.018 0.014
> female2 0.068 0.042 0.062 0.076 0.059
> param cost:=
> male0 72
> male1 544
> male2 822
> male3 825
> male4 127
> param l_cows := 3;
> end;
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
