nonzeros of a matrix
Satish Balay
balay at mcs.anl.gov
Fri Aug 11 11:24:38 CDT 2006
There is a MatGetInfo() - which returns MatInfo object. You might be
able to do PCGetFactoredMatrix() to get the factor and call
MatGetInfo() on it as well..
With bjacobi - you can call PCBJacobiGetSubKSP() to get all the solver
objects for each sub-block [and extract subpcs, and corresponding
factors etc..]
Satish
On Fri, 11 Aug 2006, Margot Summer wrote:
> Thanks. But can we find out this info inside the code (like the way we get the number of iterations of ksp)? Also, for many subpc's, e.g. using bjacobi, -ksp_view does not print out every block.
> Margot
> Satish Balay <balay at mcs.anl.gov> wrote: You can run the code with -mat_view_info [to get the matrix info] and
> -ksp_view - to get the info about the solvers [which include some
> details about the ilu preconditioner]
> Satish
> > Hi,
> > Is there a simple way to get the number of nonzeros of
> > a matrix? Further, how to find out the information
> > about a matrix object in KSP/PC, e.g., the number of
> > nonzeros of the preconditioner, or the number of
> > nonzeros of the ilu(icc) factor? Thanks,
> > Margot
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam? Yahoo! Mail has the best spam protection around
> > http://mail.yahoo.com
> Stay in the know. Pulse on the new Yahoo.com. Check it out.
