About user defined PC
jiaxun hou
jiaxun_hou at yahoo.com.cn
Tue Aug 8 04:48:48 CDT 2006
I met a problem ,when I constructed a user-defined PC. That is I need to defind the process of P^(-1)Mx in each iteration of GMRES by myself for efficient reason, not only define P^(-1)x . But the Petsc seems to separate this process into two parts: the first is y=Mx which is defined in Petsc framework, and the second is P^(-1)y which is defined by the user. So, is there any way to do it without change the code of Petsc framework?
Jiaxun
抢注雅虎免费邮箱-3.5G容量,20M附件!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060808/f193adf9/attachment.htm>
