[Petsc-trilinos-discussion] [EXTERNAL] webpage and contact list
Lofstead, Gerald F II gflofst at sandia.gov
Mon Nov 25 15:45:25 CST 2013
Example code is the biggest thing to offer here with configurations on how
to get it to build. A simple wiki may be enough. A virtual machine with it
all built inside would be excellent, but resource intensive to host.
Having a message forum structure (to some degree, the stackexchange model)
is a bit of an odd fit since there are probably a limited number of cases
and you'd probably want a discussion thread for each integration example.
Jay
On 11/25/13 2:19 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>   It sounds like we need a ³webpage" and "contact email list" for ³how
>to work with both PETSc and Trilinos in your application/library². People
>seem to think they have no place to turn to get information/advice
>(though they do, for some reason they won¹t use the resources available
>to them).
>    We could start with something like an extensible FAQ
>     1) Installing Trilinos and PETSc so they may be used together Š.
>     2) Communicating information in Trilinos objects to PETSc or in
>PETSc objects to Trilinos objects Š.
>     3) Coupling solvers that use both PETSc and Trilinos Š
>  StackExchange like technology could possibly be useful for this or
>something else? With a couple Trilinos and couple PETSc people we could
>likely work through each issue quickly.   Thoughts on technology to use
>(could be as simple as just a mailing list but we should be able to do
>something better)?
>   Barry
>_______________________________________________
>Petsc-trilinos-discussion mailing list
>Petsc-trilinos-discussion at lists.mcs.anl.gov
>https://lists.mcs.anl.gov/mailman/listinfo/petsc-trilinos-discussion
More information about the Petsc-trilinos-discussion mailing list
