[petsc-dev] Question on PETSc + CUDA configuration with MPI on cluster
    岳新海
    12332508 at mail.sustech.edu.cn
    Mon Sep 22 02:18:29 CDT 2025
Dear PETSc Team,
I am encountering an issue when running PETSc with CUDA support on a cluster. When I set the vector type to VECCUDA, PETSc reports that my MPI is not GPU-aware. However, the MPI library (OpenMPI 4.1.5) I used to configure PETSc was built with the --with-cuda option enabled.
Here are some details:
PETSc version: 3.20.6
MPI: OpenMPI 4.1.5, configured with --with-cuda
GPU: RTX3090
CUDA version: 12.1
I have attached both my PETSc configure command and OpenMPI configure command for reference.
My questions are:
Even though I enabled --with-cuda in OpenMPI, why does PETSc still report that MPI is not GPU-aware?
Are there additional steps or specific configuration flags required (either in OpenMPI or PETSc) to ensure GPU-aware MPI is correctly detected?
Any guidance or suggestions would be greatly appreciated.
Best regards,
Xinhai Yue
岳新海
南方科技大学/学生/研究生/2023级研究生
广东省深圳市南山区学苑大道1088号
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250922/632fcd9b/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250922/632fcd9b/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250922/632fcd9b/attachment-0001.obj>
