[petsc-dev] petsc4py numpy version
    Samar Khatiwala
    samar.khatiwala at earth.ox.ac.uk
    Sat Aug 16 22:04:02 CDT 2025
Hi Satish,
Thanks, that’s actually very helpful and suggests a potential solution to the problem I’m trying to solve.
Best,
Samar
> On Aug 17, 2025, at 7:03 AM, Satish Balay <balay.anl at fastmail.org> wrote:
> I'm not sure if info is saved.
> Some clarification on petsc4py usage of numpy is at: https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7745*note_2652571424__;Iw!!G_uCfscf7eWS!eTW_ya_mQtCQRUL3PblJ9RwycQkK4eWhdSvEpRtCm3Ed6SiqWwIN2Pe6T7okVcRqtKAZA9UQXJTZi_XaBQ7XqxMMlHTda6tydi71LQ$
> Satish
> On Sat, 16 Aug 2025, Samar Khatiwala wrote:
>> Hello,
>> If I have an installed petsc4py, is there a way to determine, ideally programmatically, which version of numpy it was built with?
>> Thank you,
>> Samar
