[petsc-dev] petsc4py numpy version
    Satish Balay
    balay.anl at fastmail.org
    Sat Aug 16 17:03:44 CDT 2025
I'm not sure if info is saved.
Some clarification on petsc4py usage of numpy is at: https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7745*note_2652571424__;Iw!!G_uCfscf7eWS!eICUYX4l_SMKVKzxzAww9lwu77hylHJ6kLuDbTHzFcBiig3ohIjiQa61MppIrizWUvtv9pt653mi4h62qYKFwv_ISw$
Satish
On Sat, 16 Aug 2025, Samar Khatiwala wrote:
> Hello,
> If I have an installed petsc4py, is there a way to determine, ideally programmatically, which version of numpy it was built with?
> Thank you,
> Samar
