[petsc-dev] issue with v3.21.5 build
    Jeffrey Hyman
    hymanjd at gmail.com
    Tue Apr 29 08:07:14 CDT 2025
This configure worked
./configure --COPTFLAGS='-O3' --CXXOPTFLAGS='-O3' --FOPTFLAGS='-O3
-Wno-unused-function -fallow-argument-mismatch' --with-debugging=no
--download-mpich=yes --download-hdf5=yes
--download-hdf5-fortran-bindings=yes --download-fblaslapack=yes
--download-metis=yes --download-parmetis=yes  --download-cmake=
https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!cVnnCsYnLKHwIqcW4Y5IH96l5t5gyWj4v49IKcw1w2eiGVGyqKc1VEOgso1l3qEcjhfPE4qViqnzO5MI_NcB$
--download-cmake-cc=clang --download-cmake-cxx=clang++
but then it failed on the make. configure and make attached.
Thanks again for the help. Much appreciated.
On Tue, Apr 29, 2025 at 8:53 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
> I updated brew llvm to the latest clang
> Homebrew clang version 20.1.3
> Target: arm64-apple-darwin24.3.0
> Thread model: posix
> InstalledDir: /opt/homebrew/Cellar/llvm/20.1.3/bin
> Configuration file: /opt/homebrew/etc/clang/arm64-apple-darwin24.cfg
> and that seems happier with gfortran. I'm guessing that updating my mac OS
> to sequoia mixed stuff up.
> On Tue, Apr 29, 2025 at 8:24 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>> I had tried with clang as well, but was getting this error. Looks like
>> something with the arm64. Maybe remove and reinstall gfortran?
>> TESTING: checkFortranNameMangling from
>> config.compilers(config/BuildSystem/config/compilers.py:78
>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>> details):
>>   Unknown Fortran name mangling: Are you sure the C and Fortran compilers
>> are compatible?
>>   Perhaps one is 64-bit and one is 32-bit?
>>   See https://urldefense.us/v3/__https://petsc.org/release/faq/*macos-gfortran__;Iw!!G_uCfscf7eWS!cVnnCsYnLKHwIqcW4Y5IH96l5t5gyWj4v49IKcw1w2eiGVGyqKc1VEOgso1l3qEcjhfPE4qViqnzO9bm7zue$
>> On Tue, Apr 29, 2025 at 7:56 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <balay.anl at fastmail.org>
>>> wrote:
>>>> What do you have for:
>>>> clang --version
>>>> Try:
>>>> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
>>>> -Wno-unused-function -fallow-argument-mismatch" \
>>>> --with-debugging=no --download-mpich=
>>>> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!cVnnCsYnLKHwIqcW4Y5IH96l5t5gyWj4v49IKcw1w2eiGVGyqKc1VEOgso1l3qEcjhfPE4qViqnzOxa9XB7L$  \
>>>> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
>>>> --download-fblaslapack=yes \
>>>> --download-metis=yes --download-parmetis=yes \
>>>> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
>>>> --download-cmake=
>>> You could use clang. Your g++ is broken:
>>> Error when bootstrapping CMake:
>>> Problem while running make
>>> Log of errors:
>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Bootstrap.cmk/cmake_bootstrap.log
>>> stdout:
>>> In file included from
>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/ext/string_conversions.h:43,
>>>                  from
>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/bits/basic_string.h:4154,
>>>                  from
>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/string:54,
>>>                  from
>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.h:9,
>>>                  from
>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.cxx:15:
>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:141:11: error:
>>> 'at_quick_exit' has not been declared in '::'
>>>   141 |   using ::at_quick_exit;
>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:164:11: error:
>>> 'quick_exit' has not been declared in '::'
>>>   164 |   using ::quick_exit;
>>> make: *** [cmTimestamp.o] Error 1
>>> make: *** Waiting for unfinished jobs....
>>>                       Error running configure on CMAKE: Could not
>>> execute "['./configure
>>> --prefix=/Users/hymanjd/src/petsc/arch-darwin-c-debug --parallel=8
>>> CC="/opt/homebrew/bin/gcc-14" CXX="/opt/homebrew/bin/g++-14" --
>>> -DCMAKE_USE_OPENSSL=OFF']":
>>> Anything that includes <string> looks like it will break.
>>>   Thanks,
>>>      Matt
>>> Satish
>>>> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
>>>> > Thanks, I'll give it a spin and let you know how it goes.
>>>> > JDH
>>>> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <hymanjd at gmail.com>
>>>> wrote:
>>>> > >> Hi,
>>>> > >> I am trying to build v3.21.5 to use with pflotran. I'm running into
>>>> > >> issues with cmake. configure log attached.  Any suggestions?
>>>> > > The documentation could be clearer here. We cannot use the PETSc
>>>> compilers
>>>> > > to build CMake since it explicitly does not want MPI. Thus you need
>>>> to
>>>> > > specify them yourself. That means you would need
>>>> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
>>>> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
>>>> > >   Thanks,
>>>> > >      Matt
>>>> > >> Thanks for the help,
>>>> > >> Jeffrey
>>>> > > What most experimenters take for granted before they begin their
>>>> > > experiments is infinitely more interesting than any results to
>>>> which their
>>>> > > experiments lead.
>>>> > > -- Norbert Wiener
>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
>>>> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cVnnCsYnLKHwIqcW4Y5IH96l5t5gyWj4v49IKcw1w2eiGVGyqKc1VEOgso1l3qEcjhfPE4qViqnzO2dJbFAM$
>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cVnnCsYnLKHwIqcW4Y5IH96l5t5gyWj4v49IKcw1w2eiGVGyqKc1VEOgso1l3qEcjhfPE4qViqnzO2EIQ-aS$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/534d707a/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/534d707a/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/534d707a/attachment-0003.obj>
