[petsc-dev] issue with v3.21.5 build
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 29 08:14:01 CDT 2025
On Tue, Apr 29, 2025 at 9:08 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
> This configure worked
> ./configure --COPTFLAGS='-O3' --CXXOPTFLAGS='-O3' --FOPTFLAGS='-O3
> -Wno-unused-function -fallow-argument-mismatch' --with-debugging=no
> --download-mpich=yes --download-hdf5=yes
> --download-hdf5-fortran-bindings=yes --download-fblaslapack=yes
> --download-metis=yes --download-parmetis=yes  --download-cmake=
> https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1fUXZF6g$
> --download-cmake-cc=clang --download-cmake-cxx=clang++
> but then it failed on the make. configure and make attached.
We could backport a check for this. The Python is newer than the release
3.21.5, so we are using something that went away. If you use 3.22 or higher
this is fixed.
     Matt
> Thanks again for the help. Much appreciated.
> On Tue, Apr 29, 2025 at 8:53 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>> I updated brew llvm to the latest clang
>> Homebrew clang version 20.1.3
>> Target: arm64-apple-darwin24.3.0
>> Thread model: posix
>> InstalledDir: /opt/homebrew/Cellar/llvm/20.1.3/bin
>> Configuration file: /opt/homebrew/etc/clang/arm64-apple-darwin24.cfg
>> and that seems happier with gfortran. I'm guessing that updating my mac
>> OS to sequoia mixed stuff up.
>> On Tue, Apr 29, 2025 at 8:24 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>>> I had tried with clang as well, but was getting this error. Looks like
>>> something with the arm64. Maybe remove and reinstall gfortran?
>>> TESTING: checkFortranNameMangling from
>>> config.compilers(config/BuildSystem/config/compilers.py:78
>>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>>> details):
>>>   Unknown Fortran name mangling: Are you sure the C and Fortran
>>> compilers are compatible?
>>>   Perhaps one is 64-bit and one is 32-bit?
>>>   See https://urldefense.us/v3/__https://petsc.org/release/faq/*macos-gfortran__;Iw!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1XHPsOnL$
>>> On Tue, Apr 29, 2025 at 7:56 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <balay.anl at fastmail.org>
>>>> wrote:
>>>>> What do you have for:
>>>>> clang --version
>>>>> Try:
>>>>> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
>>>>> -Wno-unused-function -fallow-argument-mismatch" \
>>>>> --with-debugging=no --download-mpich=
>>>>> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1cfTcRA7$  \
>>>>> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
>>>>> --download-fblaslapack=yes \
>>>>> --download-metis=yes --download-parmetis=yes \
>>>>> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
>>>>> --download-cmake=
>>>> You could use clang. Your g++ is broken:
>>>> Error when bootstrapping CMake:
>>>> Problem while running make
>>>> Log of errors:
>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Bootstrap.cmk/cmake_bootstrap.log
>>>> stdout:
>>>> In file included from
>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/ext/string_conversions.h:43,
>>>>                  from
>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/bits/basic_string.h:4154,
>>>>                  from
>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/string:54,
>>>>                  from
>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.h:9,
>>>>                  from
>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.cxx:15:
>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:141:11: error:
>>>> 'at_quick_exit' has not been declared in '::'
>>>>   141 |   using ::at_quick_exit;
>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:164:11: error:
>>>> 'quick_exit' has not been declared in '::'
>>>>   164 |   using ::quick_exit;
>>>> make: *** [cmTimestamp.o] Error 1
>>>> make: *** Waiting for unfinished jobs....
>>>>                       Error running configure on CMAKE: Could not
>>>> execute "['./configure
>>>> --prefix=/Users/hymanjd/src/petsc/arch-darwin-c-debug --parallel=8
>>>> CC="/opt/homebrew/bin/gcc-14" CXX="/opt/homebrew/bin/g++-14" --
>>>> -DCMAKE_USE_OPENSSL=OFF']":
>>>> Anything that includes <string> looks like it will break.
>>>>   Thanks,
>>>>      Matt
>>>> Satish
>>>>> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
>>>>> > Thanks, I'll give it a spin and let you know how it goes.
>>>>> > JDH
>>>>> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <hymanjd at gmail.com>
>>>>> wrote:
>>>>> > >> Hi,
>>>>> > >> I am trying to build v3.21.5 to use with pflotran. I'm running
>>>>> into
>>>>> > >> issues with cmake. configure log attached.  Any suggestions?
>>>>> > > The documentation could be clearer here. We cannot use the PETSc
>>>>> compilers
>>>>> > > to build CMake since it explicitly does not want MPI. Thus you
>>>>> need to
>>>>> > > specify them yourself. That means you would need
>>>>> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
>>>>> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
>>>>> > >   Thanks,
>>>>> > >      Matt
>>>>> > >> Thanks for the help,
>>>>> > >> Jeffrey
>>>>> > > What most experimenters take for granted before they begin their
>>>>> > > experiments is infinitely more interesting than any results to
>>>>> which their
>>>>> > > experiments lead.
>>>>> > > -- Norbert Wiener
>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
>>>>> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1d_Thr8_$
>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1XERab6o$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1d_Thr8_$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z-R1X20XQN9T2r9h8ePgMUitarJ7zf44Fe2AK80_Ps_l3W806bacydmdqfHuCysVMF-5EEGWsnsa1XERab6o$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/d2982ed2/attachment-0001.html>
