[petsc-dev] issue with v3.21.5 build
    Jeffrey Hyman
    hymanjd at gmail.com
    Mon Apr 28 21:05:19 CDT 2025
Apple clang version 16.0.0 (clang-1600.0.26.6)
Target: arm64-apple-darwin24.3.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
Trying now.
On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <balay.anl at fastmail.org>
wrote:
> What do you have for:
> clang --version
> Try:
> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
> -Wno-unused-function -fallow-argument-mismatch" \
> --with-debugging=no --download-mpich=
> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!YudBs_KBRbjNAvZZ8p9KlB_CmwTIqJlY2HsToPbV0_kdbwsami-PuVeXOuOQ5Gvzx-FBMR4hwoRq0sJqL1z6$  \
> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
> --download-fblaslapack=yes \
> --download-metis=yes --download-parmetis=yes \
> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
> --download-cmake=
> https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!YudBs_KBRbjNAvZZ8p9KlB_CmwTIqJlY2HsToPbV0_kdbwsami-PuVeXOuOQ5Gvzx-FBMR4hwoRq0s5NR8L0$
> --download-cmake-cc=clang --download-cmake-cxx=clang++
> Satish
> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
> > Thanks, I'll give it a spin and let you know how it goes.
> > JDH
> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <hymanjd at gmail.com>
> wrote:
> > >> Hi,
> > >> I am trying to build v3.21.5 to use with pflotran. I'm running into
> > >> issues with cmake. configure log attached.  Any suggestions?
> > > The documentation could be clearer here. We cannot use the PETSc
> compilers
> > > to build CMake since it explicitly does not want MPI. Thus you need to
> > > specify them yourself. That means you would need
> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
> > >   Thanks,
> > >      Matt
> > >> Thanks for the help,
> > >> Jeffrey
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250428/cbad41e3/attachment.html>
