[petsc-dev] PetscObjectIsNull()
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Tue Jul 30 20:27:55 CDT 2024
On 31/07/24 1:25 pm, Barry Smith wrote:
>    You need to have
> #include <petsc/finclude/petscsys.h>
>  in the file above the usage.  That is where it is defined.
I have:
#include <petsc/finclude/petsc.h>
Should that not still work?
- Adrian
>   Barry
>> On Jul 30, 2024, at 8:03 PM, Adrian Croucher
>> <a.croucher at auckland.ac.nz> wrote:
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> hi
>> I just checked out and built the latest PETSc release 3.21.4.
>> When I build my code against it, it complains that the
>> recently-introduced PetscObjectIsNull() doesn't seem to exist any more.
>> e.g.:
>> 3677 |     if (.not. PetscObjectIsNull(sf)) then
>>         |             1
>> Error: Function ‘petscobjectisnull’ at (1) has no IMPLICIT type
>> Was this removed again? It still worked when I built against the main
>> branch up until last week.
>> I deleted the build dirs for both PETSc and my code and did completely
>> clean builds of both, but got the same error.
>> - Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> Waipapa Taumata Rau / University of Auckland, New Zealand
>> email:a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
Dr Adrian Croucher
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240731/0d2fd49c/attachment-0001.html>
