[petsc-dev] PetscObjectIsNull()
Barry Smith bsmith at petsc.dev
Tue Jul 30 20:25:36 CDT 2024
   You need to have
#include <petsc/finclude/petscsys.h>
 in the file above the usage.  That is where it is defined.
  Barry
> On Jul 30, 2024, at 8:03 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> hi
> I just checked out and built the latest PETSc release 3.21.4.
> When I build my code against it, it complains that the
> recently-introduced PetscObjectIsNull() doesn't seem to exist any more.
> e.g.:
> 3677 |     if (.not. PetscObjectIsNull(sf)) then
>        |             1
> Error: Function ‘petscobjectisnull’ at (1) has no IMPLICIT type
> Was this removed again? It still worked when I built against the main
> branch up until last week.
> I deleted the build dirs for both PETSc and my code and did completely
> clean builds of both, but got the same error.
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> Waipapa Taumata Rau / University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>
> tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240730/a3874ecc/attachment-0001.html>
