[petsc-dev] bad cpu/MPI performance problem
Barry Smith bsmith at petsc.dev
Sun Jan 8 13:27:28 CST 2023
  Mark,
  Looks like the error checking in PetscCommDuplicate() is doing its job. It is reporting an attempt to use an PETSc object constructer on a subset of ranks of an MPI_Comm (which is, of course, fundamentally impossible in the PETSc/MPI model)
Note that nroots can be negative on a particular rank but DMPlexLabelComplete_Internal() is collective on sf based on the comment in the code below
struct _p_PetscSF {
  PetscInt     nroots;  /* Number of root vertices on current process (candidates for incoming edges) */
But the next routine calls a collective only when nroots >= 0
static PetscErrorCode DMPlexLabelComplete_Internal(DM dm, DMLabel label, PetscBool completeCells){
  PetscCall(PetscSFGetGraph(sfPoint, &nroots, NULL, NULL, NULL));
  if (nroots >= 0) {
    DMLabel         lblRoots, lblLeaves;
    IS              valueIS, pointIS;
    const PetscInt *values;
    PetscInt        numValues, v;
    /* Pull point contributions from remote leaves into local roots */
    PetscCall(DMLabelGather(label, sfPoint, &lblLeaves));
The code is four years old? How come this problem of calling the constructure on a subset of ranks hasn't come up since day 1?
> On Jan 8, 2023, at 12:21 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I am running on Crusher, CPU only, 64 cores per node with Plex/PetscFE.
> In going up to 64 nodes, something really catastrophic is happening.
> I understand I am not using the machine the way it was intended, but I just want to see if there are any options that I could try for a quick fix/help.
> In a debug build I get a stack trace on many but not all of the 4K processes.
> Alas, I am not sure why this job was terminated but every process that I checked, that had an "ERROR", had this stack:
> 11:57 main *+= crusher:/gpfs/alpine/csc314/scratch/adams/mg-m3dc1/src/data$ grep ERROR slurm-245063.out |g 3160
> [3160]PETSC ERROR: ------------------------------------------------------------------------
> [3160]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [3160]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3160]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
> [3160]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [3160]PETSC ERROR: The line numbers in the error traceback are not always exact.
> [3160]PETSC ERROR: #1 MPI function
> [3160]PETSC ERROR: #2 PetscCommDuplicate() at /gpfs/alpine/csc314/scratch/adams/petsc/src/sys/objects/tagm.c:248
> [3160]PETSC ERROR: #3 PetscHeaderCreate_Private() at /gpfs/alpine/csc314/scratch/adams/petsc/src/sys/objects/inherit.c:56
> [3160]PETSC ERROR: #4 PetscSFCreate() at /gpfs/alpine/csc314/scratch/adams/petsc/src/vec/is/sf/interface/sf.c:65
> [3160]PETSC ERROR: #5 DMLabelGather() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/label/dmlabel.c:1932
> [3160]PETSC ERROR: #6 DMPlexLabelComplete_Internal() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/impls/plex/plexsubmesh.c:177
> [3160]PETSC ERROR: #7 DMPlexLabelComplete() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/impls/plex/plexsubmesh.c:227
> [3160]PETSC ERROR: #8 DMCompleteBCLabels_Internal() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:5301
> [3160]PETSC ERROR: #9 DMCopyDS() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:6117
> [3160]PETSC ERROR: #10 DMCopyDisc() at /gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:6143
> [3160]PETSC ERROR: #11 SetupDiscretization() at /gpfs/alpine/csc314/scratch/adams/mg-m3dc1/src/mhd_2field.c:755
> Maybe the MPI is just getting overwhelmed.
> And I was able to get one run to to work (one TS with beuler), and the solver performance was horrendous and I see this (attached):
> Time (sec):           1.601e+02     1.001   1.600e+02
> VecMDot           111712 1.0 5.1684e+01 1.4 2.32e+07 12.8 0.0e+00 0.0e+00 1.1e+05 30  4  0  0 23  30  4  0  0 23   499
> VecNorm           163478 1.0 6.6660e+01 1.2 1.51e+07 21.5 0.0e+00 0.0e+00 1.6e+05 39  2  0  0 34  39  2  0  0 34   139
> VecNormalize      154599 1.0 6.3942e+01 1.2 2.19e+07 23.3 0.0e+00 0.0e+00 1.5e+05 38  2  0  0 32  38  2  0  0 32   189
> etc,
> KSPSolve               3 1.0 1.1553e+02 1.0 1.34e+09 47.1 2.8e+09 6.0e+01 2.8e+05 72 95 45 72 58  72 95 45 72 58  4772
> Any ideas would be welcome,
> Thanks,
> Mark
> <cushersolve.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230108/d3e1bef1/attachment.html>
