[petsc-dev] bad cpu/MPI performance problem
Mark Adams mfadams at lbl.gov
Sun Jan 8 11:21:08 CST 2023
I am running on Crusher, CPU only, 64 cores per node with Plex/PetscFE.
In going up to 64 nodes, something really catastrophic is happening.
I understand I am not using the machine the way it was intended, but I just
want to see if there are any options that I could try for a quick fix/help.
In a debug build I get a stack trace on many but not all of the 4K
processes.
Alas, I am not sure why this job was terminated but every process that I
checked, that had an "ERROR", had this stack:
11:57 main *+= crusher:/gpfs/alpine/csc314/scratch/adams/mg-m3dc1/src/data$
grep ERROR slurm-245063.out |g 3160
[3160]PETSC ERROR:
[3160]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[3160]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger
[3160]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
[3160]PETSC ERROR: ---------------------  Stack Frames
[3160]PETSC ERROR: The line numbers in the error traceback are not always
exact.
[3160]PETSC ERROR: #1 MPI function
[3160]PETSC ERROR: #2 PetscCommDuplicate() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/sys/objects/tagm.c:248
[3160]PETSC ERROR: #3 PetscHeaderCreate_Private() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/sys/objects/inherit.c:56
[3160]PETSC ERROR: #4 PetscSFCreate() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/vec/is/sf/interface/sf.c:65
[3160]PETSC ERROR: #5 DMLabelGather() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/label/dmlabel.c:1932
[3160]PETSC ERROR: #6 DMPlexLabelComplete_Internal() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/impls/plex/plexsubmesh.c:177
[3160]PETSC ERROR: #7 DMPlexLabelComplete() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/impls/plex/plexsubmesh.c:227
[3160]PETSC ERROR: #8 DMCompleteBCLabels_Internal() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:5301
[3160]PETSC ERROR: #9 DMCopyDS() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:6117
[3160]PETSC ERROR: #10 DMCopyDisc() at
/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/interface/dm.c:6143
[3160]PETSC ERROR: #11 SetupDiscretization() at
/gpfs/alpine/csc314/scratch/adams/mg-m3dc1/src/mhd_2field.c:755
Maybe the MPI is just getting overwhelmed*.*
And I was able to get one run to to work (one TS with beuler), and the
solver performance was horrendous and I see this (attached):
Time (sec):           1.601e+02     1.001   1.600e+02
VecMDot           111712 1.0 5.1684e+01 1.4 2.32e+07 12.8 0.0e+00 0.0e+00
1.1e+05 30  4  0  0 23  30  4  0  0 23   499
VecNorm           163478 1.0 6.6660e+01 1.2 1.51e+07 21.5 0.0e+00 0.0e+00
1.6e+05 39  2  0  0 34  39  2  0  0 34   139
VecNormalize      154599 1.0 6.3942e+01 1.2 2.19e+07 23.3 0.0e+00 0.0e+00
1.5e+05 38  2  0  0 32  38  2  0  0 32   189
etc,
KSPSolve               3 1.0 1.1553e+02 1.0 1.34e+09 47.1 2.8e+09 6.0e+01
2.8e+05 72 95 45 72 58  72 95 45 72 58  4772
Any ideas would be welcome,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230108/c708f675/attachment-0001.html>
+ '[' -z '' ']'
+ case "$-" in
+ __lmod_vx=x
+ '[' -n x ']'
+ set +x
Shell debugging temporarily silenced: export LMOD_SH_DBG_ON=1 for this output (/usr/share/lmod/lmod/init/bash)
Shell debugging restarted
+ unset __lmod_vx
+ NG=8
+ NC=8
+ VERSION=
+ export MPICH_OFI_NIC_POLICY=NUMA
+ MPICH_OFI_NIC_POLICY=NUMA
+ export OMP_PROC_BIND=true
+ OMP_PROC_BIND=true
+ NTPN=64
+ ORDER=2
+ DT=0.001
+ MU=0.005
+ ETA=0.0001
+ STEPS=1
+ TYPE=tilt
+ EXTRA1='-pc_type mg -ksp_type fgmres -ksp_converged_reason -pc_mg_type full -mg_levels_ksp_max_it 4 -mg_levels_ksp_type gmres -mg_levels_pc_type jacobi -log_view -ts_adapt_dt_max 0.01 -mg_coarse_pc_type gamg -mg_coarse_ksp_type fgmres -mg_coarse_mg_levels_ksp_type gmres -mg_coarse_ksp_rtol 1e-1'
+ date
Sun 08 Jan 2023 11:56:11 AM EST
+ for REFINE in 3
+ for NPIDX in 8
+ let 'N1 = 8'
+ let 'NODES = 8 * 8'
+ let 'N = 64 * 8 * 8'
+ export FILE=sol_64_3.h5
+ FILE=sol_64_3.h5
+ echo n= 4096 ' NODES=' 64 sol_64_3.h5
n= 4096  NODES= 64 sol_64_3.h5
++ printf %03d 64
+ foo=064
+ srun -n 4096 --ntasks-per-node=64 ../mhd -dm_refine_hierarchy 3 -petscspace_degree 2 -ts_dt 0.001 -mu 0.005 -eta 0.0001 -ts_max_steps 1 -ts_max_time -pc_type mg -ksp_type fgmres -ksp_converged_reason -pc_mg_type full -mg_levels_ksp_max_it 4 -mg_levels_ksp_type gmres -mg_levels_pc_type jacobi -log_view -ts_adapt_dt_max 0.01 -mg_coarse_pc_type gamg -mg_coarse_ksp_type fgmres -mg_coarse_mg_levels_ksp_type gmres -mg_coarse_ksp_rtol 1e-1
+ tee out_064_tilt_3_64
Test Type = tilt
Model Type = two-field
eta = 0.0001
mu = 0.005
DM Object: box 4096 MPI processes
  type: plex
box in 2 dimensions:
  Min/Max of 0-cells per rank: 81/90
  Min/Max of 1-cells per rank: 208/216
  Min/Max of 2-cells per rank: 128/128
Labels:
  celltype: 3 strata with value/size (1 (208), 3 (128), 0 (81))
  depth: 3 strata with value/size (0 (81), 1 (208), 2 (128))
  marker: 1 strata with value/size (1 (33))
  Face Sets: 1 strata with value/size (1 (30))
  Defined by transform from:
  DM_0x84000002_1 in 2 dimensions:
    Min/Max of 0-cells per rank:   25/30
    Min/Max of 1-cells per rank:   56/60
    Min/Max of 2-cells per rank:   32/32
  Labels:
    celltype: 3 strata with value/size (1 (56), 3 (32), 0 (25))
    depth: 3 strata with value/size (0 (25), 1 (56), 2 (32))
    marker: 1 strata with value/size (1 (17))
    Face Sets: 1 strata with value/size (1 (14))
    DM_0x84000002_2 in 2 dimensions:
      Min/Max of 0-cells per rank:     9/12
      Min/Max of 1-cells per rank:     16/18
      Min/Max of 2-cells per rank:     8/8
    Labels:
      celltype: 3 strata with value/size (1 (16), 3 (8), 0 (9))
      depth: 3 strata with value/size (0 (9), 1 (16), 2 (8))
      marker: 1 strata with value/size (1 (9))
      Face Sets: 1 strata with value/size (1 (6))
      DM_0x84000002_3 in 2 dimensions:
        Min/Max of 0-cells per rank:       4/6
        Min/Max of 1-cells per rank:       5/6
        Min/Max of 2-cells per rank:       2/2
      Labels:
        depth: 3 strata with value/size (0 (4), 1 (5), 2 (2))
        celltype: 3 strata with value/size (0 (4), 1 (5), 3 (2))
        marker: 1 strata with value/size (1 (5))
        Face Sets: 1 strata with value/size (1 (2))
0 TS dt 0.001 time 0.
MHD    0) time =         0, Eergy=  2.3259668002406e+00 (plot ID 0)
    0 SNES Function norm 4.332169496840e-02
    Linear solve converged due to CONVERGED_RTOL iterations 2
    1 SNES Function norm 1.183091626579e-05
    Linear solve converged due to CONVERGED_RTOL iterations 3
    2 SNES Function norm 5.616046049129e-09
    Linear solve converged due to CONVERGED_RTOL iterations 4
    3 SNES Function norm 7.868995994841e-13
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 3
      TSAdapt none beuler 0: step   0 accepted t=0          + 1.000e-03 dt=1.000e-03
1 TS dt 0.001 time 0.001
MHD    1) time =     0.001, Eergy=  2.3259660955830e+00 (plot ID 1)
***                                WIDEN YOUR WINDOW TO 160 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document                                 ***
------------------------------------------------------------------ PETSc Performance Summary: ------------------------------------------------------------------
/gpfs/alpine/csc314/scratch/adams/mg-m3dc1/src/data/../mhd on a arch-olcf-crusher named crusher072 with 4096 processors, by adams Sun Jan  8 11:59:06 2023
Using 1 OpenMP threads
Using Petsc Development GIT revision: v3.18.3-352-g91c56366cb1  GIT Date: 2023-01-05 17:22:48 +0000
                         Max       Max/Min     Avg       Total
Objects:              5.255e+05     1.502   3.611e+05
Flops:                1.352e+09    37.758   1.420e+08  5.816e+11
Flops/sec:            8.460e+06    37.813   8.877e+05  3.636e+09
MPI Msg Count:        5.487e+06    11.915   1.512e+06  6.195e+09
MPI Msg Len (bytes):  3.733e+08    30.110   3.779e+01  2.341e+11
MPI Reductions:       4.769e+05     1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 1.5996e+02 100.0%  5.8162e+11 100.0%  6.195e+09 100.0%  3.779e+01      100.0%  4.769e+05 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided      86094 1.0 2.2476e+01 1.5 0.00e+00 0.0 2.7e+08 4.0e+00 0.0e+00 12  0  4  0  0  12  0  4  0  0     0
BuildTwoSidedF       125 1.0 6.2748e-02 1.3 0.00e+00 0.0 6.3e+05 5.4e+03 0.0e+00  0  0  0  1  0   0  0  0  1  0     0
DMCoarsen              3 1.0 2.3923e-02 10.2 0.00e+00 0.0 7.1e+04 3.0e+01 1.4e+01  0  0  0  0  0   0  0  0  0  0     0
DMRefine              24 1.0 3.3197e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMCreateInterp         3 1.0 8.2148e+00 1.0 1.41e+05 1.9 1.4e+09 1.5e+01 8.6e+04  5  0 23  9 18   5  0 23  9 18    52
DMCreateInject         3 1.0 1.1611e-02 1.1 8.52e+02 1.0 3.7e+04 3.0e+02 3.0e+01  0  0  0  0  0   0  0  0  0  0   301
DMCreateMat            4 1.0 3.7184e-02 1.0 0.00e+00 0.0 1.2e+06 1.4e+03 5.2e+01  0  0  0  1  0   0  0  0  1  0     0
DMPlexBuFrCeLi         1 1.0 2.8821e-01 5.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexBuCoFrCeLi       1 1.0 4.2694e-04 24.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         1 1.0 4.9001e+00 1.0 0.00e+00 0.0 1.6e+04 6.5e+01 7.0e+00  3  0  0  0  0   3  0  0  0  0     0
Mesh Migration         1 1.0 1.7576e+00 1.0 0.00e+00 0.0 9.0e+04 4.5e+01 2.7e+01  1  0  0  0  0   1  0  0  0  0     0
DMPlexPartSelf         1 1.0 1.5571e+00 46740.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexPartLblInv       1 1.0 2.4942e+00 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexPartLblSF        1 1.0 2.1375e+00 1.5 0.00e+00 0.0 6.1e+03 3.5e+01 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexPartStrtSF       1 1.0 4.0332e-03 34.6 0.00e+00 0.0 4.1e+03 1.0e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexPointSF          1 1.0 2.3857e-01 6.1 0.00e+00 0.0 8.2e+03 1.3e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp          25 1.0 2.7422e-01 61.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 6.8859e+00 1.0 0.00e+00 0.0 1.1e+05 5.4e+01 3.7e+01  4  0  0  0  0   4  0  0  0  0     0
DMPlexDistCones        1 1.0 3.6314e-01 1.0 0.00e+00 0.0 2.3e+04 5.7e+01 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistLabels       1 1.0 1.0041e+00 1.0 0.00e+00 0.0 3.6e+04 4.7e+01 2.1e+01  1  0  0  0  0   1  0  0  0  0     0
DMPlexDistField        1 1.0 2.8359e-01 1.0 0.00e+00 0.0 2.7e+04 3.1e+01 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexStratify        61 1.0 1.4595e+00 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 7.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexSymmetrize      61 1.0 1.6725e-03 22.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexPrealloc         4 1.0 3.4322e-02 1.0 0.00e+00 0.0 1.2e+06 1.4e+03 4.4e+01  0  0  0  1  0   0  0  0  1  0     0
DMPlexResidualFE       4 1.0 1.4056e-02 1.1 1.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 323961
DMPlexJacobianFE      12 1.0 1.4956e-01 1.3 5.25e+06 1.0 3.2e+05 6.8e+03 1.2e+01  0  4  0  1  0   0  4  0  1  0 140688
DMPlexInterpFE         3 1.0 3.6915e-02 1.1 1.38e+04 1.0 1.6e+05 7.0e+03 3.9e+01  0  0  0  0  0   0  0  0  0  0  1533
DMPlexInjectorFE       3 1.0 9.5989e-03 1.1 8.52e+02 1.0 3.7e+04 3.0e+02 1.8e+01  0  0  0  0  0   0  0  0  0  0   364
DMPlexIntegralFEM       4 1.0 8.5999e-03 1.1 1.72e+05 1.3 9.8e+04 2.6e+02 4.0e+00  0  0  0  0  0   0  0  0  0  0 65039
SFSetGraph         86137 1.0 1.7477e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp            86094 1.0 2.3369e+01 1.5 0.00e+00 0.0 8.0e+08 1.3e+01 0.0e+00 12  0 13  4  0  12  0 13  4  0     0
SFBcastBegin      172190 1.0 1.2254e+00 6.9 0.00e+00 0.0 2.1e+09 1.7e+01 0.0e+00  0  0 33 15  0   0  0 33 15  0     0
SFBcastEnd        172190 1.0 4.6465e+00 17.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
SFReduceBegin      28707 1.0 3.4174e-01 7.7 0.00e+00 0.0 5.1e+08 3.4e+01 0.0e+00  0  0  8  7  0   0  0  8  7  0     0
SFReduceEnd        28707 1.0 2.1009e+00 185.0 1.87e+03 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
SFFetchOpBegin         8 1.0 3.9807e-04 9.8 0.00e+00 0.0 1.4e+05 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           8 1.0 8.4017e-02 357.6 0.00e+00 0.0 1.4e+05 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFCreateEmbed         12 1.0 2.6587e-02 36.4 0.00e+00 0.0 2.0e+05 9.8e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFDistSection      57349 1.0 1.9829e+01 1.4 0.00e+00 0.0 2.8e+09 1.5e+01 5.7e+04 11  0 45 18 12  11  0 45 18 12     0
SFSectionSF        57360 1.0 1.4852e+01 1.8 0.00e+00 0.0 3.2e+07 1.0e+01 0.0e+00  7  0  1  0  0   7  0  1  0  0     0
SFRemoteOff           11 1.0 2.6552e-01 244.6 0.00e+00 0.0 4.5e+05 2.3e+01 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFPack            415943 1.0 3.0997e-01 7.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFUnpack          415951 1.0 2.3806e-01 8.3 1.64e+07 4096.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2510
MatMult           164941 1.0 1.7551e+01 38.4 1.17e+09 59.2 2.7e+09 6.0e+01 0.0e+00  2 75 43 68  0   2 75 43 68  0 24851
MatMultAdd         25725 1.0 2.6326e+00 49.5 4.32e+07 44.0 8.1e+07 5.6e+01 0.0e+00  1  3  1  2  0   1  3  1  2  0  5822
MatMultTranspose   25770 1.0 4.0162e+00 86.0 6.07e+07 30.8 8.2e+07 5.8e+01 0.0e+00  0  4  1  2  0   0  4  1  2  0  5311
MatSolve            8557 0.0 1.4780e-02 0.0 3.28e+07 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2216
MatLUFactorSym         2 1.0 1.3721e-04 10.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         3 1.0 2.1736e-04 26.9 1.68e+05 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   771
MatConvert             1 1.0 8.2123e-04 2.5 0.00e+00 0.0 6.5e+04 6.1e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               6 1.0 5.9544e-05 7.8 4.96e+03 155.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 21676
MatResidual        25725 1.0 3.4553e+00 51.1 1.90e+08 90.1 3.8e+08 6.0e+01 0.0e+00  0 10  6 10  0   0 10  6 10  0 17058
MatAssemblyBegin     183 1.0 5.9995e-02 1.3 0.00e+00 0.0 6.3e+05 5.4e+03 0.0e+00  0  0  0  1  0   0  0  0  1  0     0
MatAssemblyEnd       183 1.0 6.1860e-02 1.8 1.79e+05 0.0 0.0e+00 0.0e+00 1.9e+02  0  0  0  0  0   0  0  0  0  0  2259
MatGetRowIJ            2 0.0 5.0017e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        6 1.0 1.7156e-02 1.0 0.00e+00 0.0 3.3e+03 6.7e+02 7.8e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         2 0.0 1.5178e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             3 1.0 8.4847e-02 1.0 5.50e+02 34.4 1.7e+06 6.8e+00 1.4e+02  0  0  0  0  0   0  0  0  0  0     7
MatZeroEntries        25 1.0 4.5243e-04 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                6 1.0 4.3716e-03 1.4 1.25e+03 62.4 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  0   106
MatTranspose          20 1.0 2.4047e-02 1.0 0.00e+00 0.0 2.0e+05 1.6e+01 3.6e+01  0  0  0  0  0   0  0  0  0  0     0
MatMatMultSym         18 1.0 8.2997e-03 1.4 0.00e+00 0.0 1.5e+05 1.1e+02 3.2e+01  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum         24 1.0 2.2100e-03 2.3 7.44e+05 612.7 4.8e+04 2.2e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0 53891
MatPtAPSymbolic        7 1.0 9.4411e-02 1.0 0.00e+00 0.0 4.8e+05 2.1e+02 4.9e+01  0  0  0  0  0   0  0  0  0  0     0
MatPtAPNumeric        10 1.0 3.1720e-02 1.0 2.07e+06 748.2 1.0e+05 1.0e+03 2.8e+01  0  0  0  0  0   0  0  0  0  0  9180
MatGetLocalMat        18 1.0 3.4709e-04 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         18 1.0 7.4246e-03 4.2 0.00e+00 0.0 6.3e+05 2.2e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecDot                 3 1.0 7.5026e-04 3.6 7.34e+03 1.4 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0 33461
VecMDot           111712 1.0 5.1684e+01 1.4 2.32e+07 12.8 0.0e+00 0.0e+00 1.1e+05 30  4  0  0 23  30  4  0  0 23   499
VecNorm           163478 1.0 6.6660e+01 1.2 1.51e+07 21.5 0.0e+00 0.0e+00 1.6e+05 39  2  0  0 34  39  2  0  0 34   139
VecScale          163474 1.0 4.1438e-02 2.3 7.62e+06 20.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 114115
VecCopy            51501 1.0 1.0359e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            154784 1.0 2.2054e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            77515 1.0 1.5456e-02 1.8 7.34e+06 23.6 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 260335
VecAYPX            25725 1.0 4.0271e-03 2.0 1.22e+06 26.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 159416
VecAXPBYCZ             5 1.0 3.0874e-04 15.7 1.84e+04 1.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 203383
VecWAXPY             273 1.0 4.0046e-04 4.4 1.66e+04 4.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 74858
VecMAXPY          163474 1.0 2.8194e-02 1.6 3.28e+07 12.8 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 1182751
VecAssemblyBegin      54 1.0 7.6876e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        54 1.0 2.9547e-04 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult  154605 1.0 2.6318e-02 2.0 7.36e+06 22.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 156279
VecScatterBegin   215038 1.0 4.8206e+00 30.5 0.00e+00 0.0 2.8e+09 6.0e+01 0.0e+00  0  0 45 72  0   0  0 45 72  0     0
VecScatterEnd     215038 1.0 1.8449e+01 81.5 1.64e+07 4357.6 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0    32
VecReduceArith         6 1.0 5.2762e-05 13.8 1.47e+04 1.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 951609
VecReduceComm          3 1.0 5.8082e-04 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize      154599 1.0 6.3942e+01 1.2 2.19e+07 23.3 0.0e+00 0.0e+00 1.5e+05 38  2  0  0 32  38  2  0  0 32   189
DualSpaceSetUp        30 1.0 1.5583e-01 35.4 1.91e+03 1.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0    50
FESetUp               30 1.0 4.3889e-01 6.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
TSStep                 1 1.0 1.2428e+02 1.0 1.35e+09 38.0 4.3e+09 4.5e+01 3.6e+05 78 100 69 83 76  78 100 69 83 76  4674
TSFunctionEval         4 1.0 2.2100e-02 1.6 1.19e+06 1.1 2.1e+05 3.2e+02 0.0e+00  0  1  0  0  0   0  1  0  0  0 207155
TSJacobianEval        12 1.0 1.5598e-01 1.2 5.40e+06 1.1 8.3e+05 2.7e+03 1.8e+01  0  4  0  1  0   0  4  0  1  0 135286
KSPSetUp              33 1.0 6.4498e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               3 1.0 1.1553e+02 1.0 1.34e+09 47.1 2.8e+09 6.0e+01 2.8e+05 72 95 45 72 58  72 95 45 72 58  4772
KSPGMRESOrthog    111712 1.0 5.1726e+01 1.4 4.67e+07 12.3 0.0e+00 0.0e+00 1.1e+05 30  9  0  0 23  30  9  0  0 23  1011
SNESSolve              1 1.0 1.2426e+02 1.0 1.35e+09 38.0 4.3e+09 4.5e+01 3.6e+05 78 100 69 82 76  78 100 69 82 76  4675
SNESSetUp              1 1.0 1.5743e-02 1.0 0.00e+00 0.0 3.0e+05 2.9e+03 1.3e+01  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       4 1.0 2.2331e-02 1.6 1.20e+06 1.1 2.1e+05 3.2e+02 0.0e+00  0  1  0  0  0   0  1  0  0  0 207265
SNESJacobianEval      12 1.0 1.5644e-01 1.2 5.40e+06 1.1 8.3e+05 2.7e+03 2.4e+01  0  4  0  1  0   0  4  0  1  0 134890
SNESLineSearch         3 1.0 1.8880e-02 1.0 1.27e+06 1.1 2.7e+05 3.8e+02 1.2e+01  0  1  0  0  0   0  1  0  0  0 250629
PCSetUp_GAMG+          3 1.0 2.9065e-01 1.0 2.41e+06 368.0 3.1e+06 9.0e+01 6.6e+02  0  0  0  0  0   0  0  0  0  0  1370
 PCGAMGCreateG         3 1.0 1.2053e-02 1.0 6.87e+02 171.8 1.8e+05 1.6e+01 5.4e+01  0  0  0  0  0   0  0  0  0  0    16
 GAMG Coarsen          3 1.0 8.4956e-02 1.0 5.50e+02 34.4 1.7e+06 6.8e+00 1.4e+02  0  0  0  0  0   0  0  0  0  0     7
  GAMG MIS/Agg         3 1.0 8.4865e-02 1.0 5.50e+02 34.4 1.7e+06 6.8e+00 1.4e+02  0  0  0  0  0   0  0  0  0  0     7
 PCGAMGProl            3 1.0 2.2059e-02 1.0 0.00e+00 0.0 1.1e+05 5.0e+01 1.3e+02  0  0  0  0  0   0  0  0  0  0     0
  GAMG Prol-col        3 1.0 1.8696e-02 1.0 0.00e+00 0.0 1.1e+05 1.9e+01 1.0e+02  0  0  0  0  0   0  0  0  0  0     0
  GAMG Prol-lift       3 1.0 2.0733e-03 1.1 0.00e+00 0.0 8.5e+03 4.3e+02 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
 PCGAMGOptProl         3 1.0 1.6406e-02 1.0 3.51e+05 120.5 6.8e+05 8.0e+01 1.1e+02  0  0  0  0  0   0  0  0  0  0  6513
  GAMG smooth          3 1.0 8.6092e-03 1.4 9.23e+04 156.0 1.8e+05 1.5e+02 3.0e+01  0  0  0  0  0   0  0  0  0  0  3065
 PCGAMGCreateL         3 1.0 4.9664e-02 1.0 6.52e+05 714.4 2.0e+05 3.7e+02 1.8e+02  0  0  0  0  0   0  0  0  0  0  1949
  GAMG PtAP            3 1.0 1.8299e-02 1.0 6.52e+05 714.4 2.0e+05 3.7e+02 3.3e+01  0  0  0  0  0   0  0  0  0  0  5290
  GAMG Reduce          3 1.0 3.1419e-02 1.0 0.00e+00 0.0 7.0e+03 3.5e+02 1.5e+02  0  0  0  0  0   0  0  0  0  0     0
PCGAMG Gal l00         3 1.0 9.4588e-02 1.0 3.25e+05 118.7 4.2e+05 4.4e+02 2.2e+01  0  0  0  0  0   0  0  0  0  0  2688
PCGAMG Opt l00         1 1.0 3.5215e-03 2.0 2.19e+04 42.8 1.7e+05 1.5e+02 8.0e+00  0  0  0  0  0   0  0  0  0  0  6627
PCGAMG Gal l01         3 1.0 1.9694e-02 1.3 9.33e+05 0.0 8.2e+03 1.8e+03 2.2e+01  0  0  0  0  0   0  0  0  0  0  1505
PCGAMG Opt l01         1 1.0 1.5205e-03 1.1 2.78e+04 0.0 2.4e+03 3.2e+02 8.0e+00  0  0  0  0  0   0  0  0  0  0   745
PCGAMG Gal l02         3 1.0 1.0422e-02 1.4 1.27e+06 0.0 6.1e+02 2.2e+03 2.2e+01  0  0  0  0  0   0  0  0  0  0   650
PCGAMG Opt l02         1 1.0 1.5479e-03 1.0 6.39e+04 0.0 2.1e+02 5.9e+02 8.0e+00  0  0  0  0  0   0  0  0  0  0   232
PCSetUp                6 1.0 8.6265e+00 1.0 4.24e+06 2.5 1.5e+09 1.6e+01 8.7e+04  5  1 23 10 18   5  1 23 10 18   904
PCSetUpOnBlocks     8557 1.0 4.3035e-03 4.2 1.68e+05 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    39
PCApply                9 1.0 1.1553e+02 1.0 1.34e+09 48.4 2.8e+09 6.0e+01 2.8e+05 72 94 45 72 58  72 94 45 72 58  4738
--- Event Stage 1: Unknown
Object Type          Creations   Destructions. Reports information only for process 0.
           Container   107            107
    Distributed Mesh   138            138
            DM Label 57648          57648
          Quadrature   512            512
      Mesh Transform   177            177
           Index Set 190065          190065
   IS L to G Mapping     5              5
             Section 115247          115247
   Star Forest Graph 86394          86394
     Discrete System   261            261
           Weak Form   277            277
    GraphPartitioner    62             62
              Matrix   314            314
      Matrix Coarsen     3              3
              Vector   497            497
        Linear Space     8              8
          Dual Space    58             58
            FE Space    30             30
              Viewer     2              1
             TSAdapt     1              1
                  TS     1              1
                DMTS     1              1
                SNES     1              1
              DMSNES     6              6
      SNESLineSearch     1              1
       Krylov Solver    13             13
     DMKSP interface     4              4
      Preconditioner    13             13
       Field over DM     4              4
         PetscRandom     3              3
Average time to get PetscTime(): 4.61e-08
Average time for MPI_Barrier(): 3.05634e-05
Average time for zero size MPI_Send(): 9.29304e-06
#PETSc Option Table entries:
-dm_plex_box_faces 64,64 # (source: code)
-dm_plex_box_lower -2,-2 # (source: code)
-dm_plex_box_upper 2,2 # (source: code)
-dm_plex_simplex 1 # (source: file)
-dm_refine_hierarchy 3 # (source: command line)
-eta 0.0001 # (source: command line)
-ksp_converged_reason # (source: command line)
-ksp_max_it 50 # (source: file)
-ksp_rtol 1e-3 # (source: file)
-ksp_type fgmres # (source: command line)
-log_view # (source: command line)
-mg_coarse_ksp_rtol 1e-1 # (source: command line)
-mg_coarse_ksp_type fgmres # (source: command line)
-mg_coarse_mg_levels_ksp_type gmres # (source: command line)
-mg_coarse_pc_type gamg # (source: command line)
-mg_levels_ksp_max_it 4 # (source: command line)
-mg_levels_ksp_type gmres # (source: command line)
-mg_levels_pc_type jacobi # (source: command line)
-mu 0.005 # (source: command line)
-options_left # (source: file)
-pc_mg_type full # (source: command line)
-pc_type mg # (source: command line)
-petscpartitioner_type simple # (source: code)
-petscspace_degree 2 # (source: command line)
-snes_converged_reason # (source: file)
-snes_max_it 10 # (source: file)
-snes_monitor # (source: file)
-snes_rtol 1.e-9 # (source: file)
-snes_stol 1.e-9 # (source: file)
-ts_adapt_dt_max 0.01 # (source: command line)
-ts_adapt_monitor # (source: file)
-ts_arkimex_type 1bee # (source: file)
-ts_dt 0.001 # (source: command line)
-ts_max_reject 10 # (source: file)
-ts_max_snes_failures -1 # (source: file)
-ts_max_steps 1 # (source: command line)
-ts_max_time # (source: command line)
-ts_monitor # (source: file)
-ts_type beuler # (source: file)
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=cc --with-cxx=CC --with-fc=ftn LIBS="-L/opt/cray/pe/mpich/8.1.17/gtl/lib -lmpi_gtl_hsa" --with-openmp=1 --with-debugging=0 --with-64-bit-indices=0 --with-mpiexec=srun --download-superlu --download-superlu_dist --download-mumps --download-scalapack --download-hdf5=1 --download-triangle PETSC_ARCH=arch-olcf-crusher
Libraries compiled on 2023-01-07 16:22:45 on login2
Machine characteristics: Linux-5.3.18-150300.59.87_11.0.78-cray_shasta_c-x86_64-with-glibc2.3.4
Using PETSc directory: /gpfs/alpine/csc314/scratch/adams/petsc
Using PETSc arch: arch-olcf-crusher
Using C compiler: cc  -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g -O3   -fopenmp
Using Fortran compiler: ftn  -fPIC   -fopenmp    -fopenmp
Using include paths: -I/gpfs/alpine/csc314/scratch/adams/petsc/include -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/include
Using C linker: cc
Using Fortran linker: ftn
Using libraries: -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -lpetsc -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -L/opt/cray/pe/mpich/8.1.17/gtl/lib -ldmumps -lmumps_common -lpord -lpthread -lscalapack -lsuperlu -lsuperlu_dist -lhdf5_hl -lhdf5 -ltriangle -lquadmath -lmpifort_cray -lmpi_gtl_hsa
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:-ts_arkimex_type value: 1bee source: file
+ date
Sun 08 Jan 2023 11:59:07 AM EST
