[petsc-dev] Apply for Google Summer of Code 2023?
Karl Rupp rupp at iue.tuwien.ac.at
Mon Feb 6 13:24:41 CST 2023
Hello all,
thanks for proposing projects. I've created the suggestions so far as
'issues' in the issue tracker on Gitlab, prefixed by 'GSoC:'. Please add
a better description to your suggestions so that applicants get a better
idea of what that project is all about and how to get started. :-)
Also, Satish, Junchao, Jed, and Matt should have received invitations to
join the PETSc org for GSoC 2023. Please join today, as we need to apply
by tomorrow (Tuesday) 18:00 UTC.
I've got one question regarding payment processing; since that is a bit
sensitive, I'll send it to the private list petsc-maint.
Thanks and best regards,
Karli
On 2/4/23 20:46, Matthew Knepley wrote:
> On Fri, Feb 3, 2023 at 6:28 PM Jed Brown <jed at jedbrown.org
> <mailto:jed at jedbrown.org>> wrote:
>     Thanks for proposing this. Some ideas:
>     * DMPlex+libCEED automation
>     * Pipelined Krylov methods using Rust async
>     * Differentiable programming using Enzyme with PETSc
> I like all those.
>    Matt
>     Karl Rupp <rupp at iue.tuwien.ac.at <mailto:rupp at iue.tuwien.ac.at>> writes:
>      > Dear PETSc developers,
>      > in order to attract students to PETSc development, I'm thinking
>     about a
>      > PETSc application for Google Summer of Code (GSoC) 2023:
>      > https://summerofcode.withgoogle.com/programs/2023
>     <https://summerofcode.withgoogle.com/programs/2023>
>      > The org application deadline is February 7, i.e. in 4 days. This
>      > application is - roughly speaking - a form with a state of intent
>     and a
>      > justification why the project is a good fit for GSoC. I've done
>     this in
>      > the past (~2010-12) and can do the paperwork again this year.
>      > What is required:
>      >   - PETSc developers, who are willing to act as mentors
>     throughout the
>      > program.
>      >   - A few good project ideas (e.g. MATDENSE for GPUs) for
>      > contributors/students to work on
>      > It used to be that new organizations will get at most 2 contributor
>      > slots assigned. That's fair, because one must not underestimate the
>      > effort that goes into mentoring.
>      > Thoughts? Shall we apply (yes/no)? If yes, are you willing to be
>     mentor?
>      > The more mentors, the better; it underlines the importance of the
>      > project and indicates that contributors will find a good environment.
>      > Karli
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
