[petsc-dev] Symbol names using clang in addition to gcc
Thu Sep 22 13:12:54 CDT 2022
MR with this fix at https://gitlab.com/petsc/petsc/-/merge_requests/5672
Satish
On Thu, 22 Sep 2022, Satish Balay via petsc-dev wrote:
> Perhaps the following change.
> Satish
> diff --git a/src/sys/dll/dlimpl.c b/src/sys/dll/dlimpl.c
> index fc488603167..63eba0d2fb3 100644
> --- a/src/sys/dll/dlimpl.c
> +++ b/src/sys/dll/dlimpl.c
> @@ -327,7 +327,7 @@ PetscErrorCode PetscDLAddr(void (*func)(void), char **name)
>    PetscFunctionBegin;
>    PetscValidPointer(name, 2);
>    *name = NULL;
> -#if defined(PETSC_HAVE_DLADDR) && defined(__USE_GNU)
> +#if defined(PETSC_HAVE_DLADDR) && !(defined(__cray__) && defined(__clang__))
>    dlerror(); /* clear any previous error */
>      Dl_info info;
> diff --git a/src/sys/objects/pinit.c b/src/sys/objects/pinit.c
> index 7694a0b496b..7b51f90d1d4 100644
> --- a/src/sys/objects/pinit.c
> +++ b/src/sys/objects/pinit.c
> @@ -829,7 +829,7 @@ PETSC_INTERN PetscErrorCode PetscInitialize_Common(const char *prog, const char
>  #endif
> -#if PetscDefined(HAVE_DLSYM) && defined(__USE_GNU)
>    /* These symbols are currently in the OpenMPI and MPICH libraries; they may not always be, in that case the test will simply not detect the problem */
>    PetscCheck(!dlsym(RTLD_DEFAULT, "ompi_mpi_init") || !dlsym(RTLD_DEFAULT, "MPID_Abort"), PETSC_COMM_SELF, PETSC_ERR_MPI_LIB_INCOMP, "Application was linked against both OpenMPI and MPICH based MPI libraries and will not run correctly");
>  #endif
> > Actually the failure on Cray is with clang.
> > So I'm not sure the best way to fix this is.
> > Satish
> > [balay at login2.crusher petsc]$ CC --version
> > Cray clang version 14.0.0  (c98838affc7b58fed2a72f164d77c35e1bc8772f)
> > Target: x86_64-unknown-linux-gnu
> > Thread model: posix
> > InstalledDir: /opt/cray/pe/cce/14.0.0/cce-clang/x86_64/share/../bin
> > [balay at login2.crusher petsc]$ git diff src/sys/dll/dlimpl.c |cat
> > index fc488603167..c73edb99f90 100644
> >    PetscFunctionBegin;
> >    *name = NULL;
> > +#if defined(PETSC_HAVE_DLADDR) && (defined(__USE_GNU) || defined(__clang__))
> >      Dl_info info;
> > [balay at login2.crusher petsc]$ make libs
> >           CC arch-olcf-crusher/obj/sys/dll/dlimpl.o
> > /autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:333:5: error: use of undeclared identifier 'Dl_info'
> >     Dl_info info;
> > /autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:335:16: warning: implicit declaration of function 'dladdr' is invalid in C99 [-Wimplicit-function-declaration]
> >     PetscCheck(dladdr(*(void **)&func, &info), PETSC_COMM_SELF, PETSC_ERR_LIB, "Failed to lookup symbol: %s", dlerror());
> > /autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:335:41: error: use of undeclared identifier 'info'
> > /autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:337:35: error: use of undeclared identifier 'info'
> >     PetscCall(PetscDemangleSymbol(info.dli_sname, name));
> > 1 warning and 3 errors generated.
> > make: *** [gmakefile:195: arch-olcf-crusher/obj/sys/dll/dlimpl.o] Error 1
> > > I see this is change was done at https://gitlab.com/petsc/petsc/-/merge_requests/5268
> > > Likely due to errors with cray compilers.
> > > So  I guess we could add in __clang__ as you suggest. Can you create an MR with this change?
> > > And probably the same fix for src/sys/objects/pinit.c ?
> > > Satish
> > > On Thu, 22 Sep 2022, Aagaard, Brad T via petsc-dev wrote:
> > > > Satish,
> > > > I used to be able to get symbol names using clang (macOS) and this still works, but I need to edit the defines in dlimpl.c because __USE_GNU is not defined. Is there a reason why the current code is limited to __USE_GNU and doesn’t allow broader use when it works?
> > > > Here is the change I made to my local version to allow symbol names.
> > > > index 5bd68aa5a33..ded4ce5adbb 100644
> > > > @@ -323,7 +323,7 @@ PetscErrorCode PetscDLAddr(void (*func)(void), char **name) {
> > > >    PetscFunctionBegin;
> > > >    *name = NULL;
> > > >      Dl_info info;
> > > > Thanks,
> > > > Brad
