[petsc-dev] do all MIS algorithms require a symmetric structure?
Barry Smith bsmith at petsc.dev
Sun Sep 18 17:19:20 CDT 2022
  Mark,
    Some how your changes to GAMG in June slowed down the time to compute the MIS dramatically. I cannot figure out what options to use to
get the exact same performance as an older branch. -mat_coarsen_type mis -pc_gamg_threshold 0 result in longer times than the older code with its default options.
> On Sep 18, 2022, at 4:21 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sun, Sep 18, 2022 at 4:02 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>   Mark,
>    Do all MIS algorithms  in PETSc require a symmetric graph structure? And parallel ones can hang if not structurally symmetric?
> Yes,
>    When used sequentially I guess it never hangs but it may not produce a "correct" MIS if the matrix structure is not symmetric?
> It is fine in serial and it is not necessarily an MIS of the symmetrized graph.
> If there is a one way edge between two vertices and the order of the greedy MIS process picks the root of the edge it is an MIS of the symmetrized graph, otherwise both vertices could get selected.
> But like the MIS is fine for GAMG in this circumstance?
> It will be fine for GAMG. The MIS is just a heuristic.
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220918/ebfa2a04/attachment-0001.html>
