[petsc-dev] Potential memory leak in PETSc - hypre interface when using Euclid
Emil Constantinescu emconsta at anl.gov
Thu Oct 27 15:27:05 CDT 2022
Hi there,
Tang Qi (LANL) reported a potential memory leak when using hypre/Euclid.
Upon rudimentary testing, I could reproduce it for many examples in
PETSc TS. The symptom is memory usage (measured with top)  with the
number of time steps. Without Euclid, memory use does not increase.
For instance, one can try ex15 under TS:
ex15  -da_grid_x 50 -da_grid_y 50 -boundary 0 -ts_max_steps 20 -Jtype 1
-ts_monitor -pc_type hypre -pc_hypre_boomeramg_smooth_type Euclid
I am not sure if it's PETSc - hypre that causes the memory use or hypre
itself.
Can someone with more sophisticated tools take a look at it?
Emil
