[petsc-dev] [petsc-users] Regarding the status of MatSolve on GPUs
Junchao Zhang
junchao.zhang at gmail.com
Wed Oct 19 10:41:22 CDT 2022
Sherry, sorry to ping you again for this issue.
--Junchao Zhang
On Tue, Oct 11, 2022 at 11:04 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Hi, Sherry,
> A petsc user wants to call MatSolve(mat, b, x) multiple times with
> different b on GPUs. In petsc, the code is like
> PetscScalar *bptr = NULL;
> VecGetArray(b, &bptr)
> pdgssvx3d(.., bptr, ..);
> Note VecGetArray() returns a host pointer. If vector b's latest data is on
> GPU, PETSc needs to do a device to host memory copy. Now we want to save
> this memory copy and directly pass b's device pointer (obtained
> via VecCUDAGetArray()) to superlu_dist. But I did not find a mechanism for
> me to tell superlu_dist that bptr is a device pointer.
> Do you have suggestions?
> Thanks
> On Thu, Oct 6, 2022 at 2:32 PM Sajid Ali <sajidsyed2021 at u.northwestern.edu>
> wrote:
>> Hi PETSc-developers,
>> Does PETSc currently provide (either native or third party support) for
>> MatSolve that can be performed entirely on a GPU given a factored matrix?
>> i.e. a direct solver that would store the factors L and U on the device and
>> use the GPU to solve the linear system. It does not matter if the GPU is
>> not used for the factorization as we intend to solve the same linear system
>> for 100s of iterations and thus try to prevent GPU->CPU transfers for the
>> MatSolve phase.
>> Currently, I've built PETSc at main (commit 9c433d, 10/03) with
>> superlu-dist at develop, both of which are configured with CUDA. With this,
>> I'm seeing that each call to PCApply/MatSolve involves one GPU->CPU
>> transfer. Is it possible to avoid this?
>> Thank You,
>> Sajid Ali (he/him) | Research Associate
>> Scientific Computing Division
>> Fermi National Accelerator Laboratory
>> s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20221019/3f5c966a/attachment-0001.html>
