[petsc-dev] Manualpage TOC
Barry Smith bsmith at petsc.dev
Mon Oct 10 10:56:04 CDT 2022
  Oh yes, thanks. Maybe the material at the bottom could be reordered and cleaned up to look like the top used to look. I didn't realize I had destroyed all the structure, I thought I was just removing duplicate lists.
  Barry
> On Oct 10, 2022, at 11:26 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> https://gitlab.com/petsc/petsc/-/merge_requests/5724/diffs
> * [API Changes in each release](../changes/index.rst)
> * [MPI](http://www.mpich.org/static/docs/latest/)
> * [Vector Operations (Vec)](Vec/index.md)
> etc was removed. I assumed it wasn't easy to migrate that to  rst format.
> prev: https://petsc.gitlab.io/-/petsc/-/jobs/3147219016/artifacts/public/html/docs/manualpages/index.html
> current: https://petsc.org/release/docs/manualpages/
> Satish
> On Mon, 10 Oct 2022, Barry Smith wrote:
>>  What is worse about it? What did it look like before? How would you like it to look?
>>   The left hand side on this page is broken and I do not know how to fix it. But the middle panel can be changed to whatever is better
>>> On Oct 10, 2022, at 8:47 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> The new push got rid of the top level organization on this page
>>>  https://petsc.org/main/docs/manualpages/ <https://petsc.org/main/docs/manualpages/>
>>> To me, this looks much worse. Is there any way to restore it
>>> without reversing the speed gains?
>>>   Matt
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
