[petsc-dev] Manualpage TOC
Satish Balay
balay at mcs.anl.gov
Mon Oct 10 10:26:16 CDT 2022
https://gitlab.com/petsc/petsc/-/merge_requests/5724/diffs
* [API Changes in each release](../changes/index.rst)
* [MPI](http://www.mpich.org/static/docs/latest/)
* [Vector Operations (Vec)](Vec/index.md)
etc was removed. I assumed it wasn't easy to migrate that to rst format.
prev: https://petsc.gitlab.io/-/petsc/-/jobs/3147219016/artifacts/public/html/docs/manualpages/index.html
current: https://petsc.org/release/docs/manualpages/
Satish
On Mon, 10 Oct 2022, Barry Smith wrote:
> What is worse about it? What did it look like before? How would you like it to look?
> The left hand side on this page is broken and I do not know how to fix it. But the middle panel can be changed to whatever is better
> > On Oct 10, 2022, at 8:47 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > The new push got rid of the top level organization on this page
> > https://petsc.org/main/docs/manualpages/ <https://petsc.org/main/docs/manualpages/>
> > To me, this looks much worse. Is there any way to restore it
> > without reversing the speed gains?
> > Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
