[petsc-dev] Telescope usage
    Loic Gouarin
    loic.gouarin at polytechnique.edu
    Tue May 17 06:18:15 CDT 2022
Le 17/05/2022 à 12:03, Dave May a écrit :
> On Tue 17. May 2022 at 11:56, Loic Gouarin
> <loic.gouarin at polytechnique.edu> wrote:
>     Hi Dave,
>     could you explain what you mean by state ?
> Ah - by state Matt and I mean any auxiliary data stored in the user
> context passed to KSPSetComputeOperators which is required to define
> your operator and is distributed. For example, a Vec which is used
> store coefficients of your PDE.
Yes, I have a context which gives the operators (mult and diagonal) and
some other informations to build the matrix free on each multigrid level.
You can find the idea here:
https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L49-L91
It's the definition of the operator used inside DMKSPComputeOperators.
Loic
>     Thanks,
>     Loic
>     Le 17/05/2022 à 11:50, Dave May a écrit :
>>     Hi Loic,
>>     Can you confirm if your problem has stored state which needs to
>>     be repartitioned?
>>     Thanks,
>>     Dave
>>     On Tue 17. May 2022 at 09:07, Loic Gouarin
>>         Le 17/05/2022 à 01:43, Dave May a écrit :
>>>         On Tue, 17 May 2022 at 00:12, Matthew Knepley
>>>         <knepley at gmail.com> wrote:
>>>             On Mon, May 16, 2022 at 9:59 AM Loic Gouarin
>>>                 Le 16/05/2022 à 21:54, Barry Smith a écrit :
>>>>>                 On May 16, 2022, at 3:50 PM, Loic Gouarin
>>>>>                 Thanks Barry for your quick reply.
>>>>>                 Le 16/05/2022 à 21:41, Barry Smith a écrit :
>>>>>>                   Loic,
>>>>>>                     From your code it looks like you are using a
>>>>>>                 DM. Is it a DMDA or a shell DM? If it is a DMDA
>>>>>>                 then the process is intended to be pretty
>>>>>>                 straightforward. PCTELESCOPE should create a new
>>>>>>                 DMDA that has the same properties as the coarse
>>>>>>                 grid DMDA but lives on a smaller number of ranks.
>>>>>>                 From this you can just provide multiple levels of
>>>>>>                 coarsening of the DMDA to produce the smaller
>>>>>>                 multigrid problems.
>>>>>                 It's a DMDA. So what you mean is to take the KSP
>>>>>                 of PCTELESCOPE, get the DM which is the same of
>>>>>                 the coarse grid and build all the levels as
>>>>>                 previously for the levels of PCTELESCOPE ?
>>>>                   Yes, I think you should be able to pull out of
>>>>                 the coarse level PC (on the subset of ranks) a DM
>>>>                 that and then setup coarse levels from that. But
>>>>                 you need to look at an example that that uses
>>>>                 telescope and probably even the telescope code
>>>>                 itself to see all the details. I don't know them
>>>>                 anymore.
>>>                 I looked at the source code but It didn't help. I
>>>                 will try to explain more clearly my experiments to
>>>                 understand what I make wrong and you can help more
>>>                 easily.
>>>             Hi Loic!
>>>             Here is my guess. When TELESCOPE redistributes the
>>>             coarse grid DMDA, it creates a new DMDA and copies over
>>>             all the information it can see. However, I think you may
>>>             have state that is attached to the old DMDA that is not
>>>             getting redistributed. If this is true, I can help you
>>>             write a hook that redistributes that state when
>>>             TELESCOPE maps between distributions.
>>>         If you have state you need to propagate between different
>>>         communicators, you will have to use the telescope type which
>>>         is internally is referred to as
>>>         TELESCOPE_COARSEDM
>>>         To activate this type you need the option
>>>         -pc_telescope_use_coarse_dm
>>>         Or to call PCTelescopeSetUseCoarseDM()
>>>         The assumptions of usng this options are described here
>>>         https://petsc.org/main/docs/manualpages/PC/PCTelescopeSetUseCoarseDM
>>>         and source associated with the COARSEDM
>>>         https://petsc.org/main/src/ksp/pc/impls/telescope/telescope_coarsedm.c.html
>>>         Using TELESCOPE_COARSEDM you will have access to the hooks
>>>         Matt is referring to.
>>         Thanks Matthew and Dave.
>>         I used TELESCOPE_COARSEDM in my previous tests but it tells
>>         me that "Zero instances of a coarse DM were found". And
>>         indeed, my coarse solver only has the DM on the coarse mesh
>>         and not on the fine level with a coarse DM atttached. I think
>>         it's because I use DMKSPSetComputeOperators to create the KSP
>>         on each level.
>>         So for now, I just added
>>         KSP coarse;
>>         ierr=PCMGGetCoarseSolve(pc_i, &coarse);CHKERRQ(ierr);
>>         PC pc_coarse;
>>         ierr=KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
>>         ierr=PCSetType(pc_coarse, PCTELESCOPE);CHKERRQ(ierr);
>>         ierr=PCTelescopeSetUseCoarseDM(pc_coarse,
>>         PETSC_TRUE);CHKERRQ(ierr);
>>         but it's not enough.
>>         Cheers,
>>         Loic
>>>         Cheers,
>>>         Dave
>>>                Thanks,
>>>                  Matt
>>>                 Thanks,
>>>                 Loic
>>>>                   Barry
>>>>>>                    Can you let us know more details of what
>>>>>>                 exactly goes wrong with attempts? It is likely
>>>>>>                 straightforward to get things working, perhaps
>>>>>>                 due to our unclear documentation.
>>>>>                 I essentially have wrong state or NULL matrices
>>>>>                 into the PCTELESCOPE.
>>>>>                 Loic
>>>>>>                   Barry
>>>>>>>                 On May 16, 2022, at 3:28 PM, Loic Gouarin
>>>>>>>                 Hello,
>>>>>>>                 I could have posted my message on the user list
>>>>>>>                 but it seems to me that it's more in the petsc
>>>>>>>                 development part. Don't hesitate to tell me if
>>>>>>>                 I'm wrong.
>>>>>>>                 I am developing a code called cafes that studies
>>>>>>>                 fluid-particle interactions in a Stokes fluid.
>>>>>>>                 For that, we implemented the whole solver in
>>>>>>>                 matrix free on a cartesian grid. The
>>>>>>>                 preconditioner is naturally a geometrical
>>>>>>>                 multigrid for the velocity. The set of matrix
>>>>>>>                 free for each level is set by hand (I worked
>>>>>>>                 with Matthew on this a long time ago now!).
>>>>>>>                 I would have liked to implement telescope on
>>>>>>>                 this part. I started it but I didn't get out of
>>>>>>>                 it. So I would like to have your help.
>>>>>>>                 What I tried to do was to describe my classical
>>>>>>>                 multigrid up to a level N1 and then take the
>>>>>>>                 coarse solver and apply the telescope
>>>>>>>                 preconditioner to it up to a level N2. I don't
>>>>>>>                 know if this is the best way but it seemed the
>>>>>>>                 most intuitive. The problem is that I could not
>>>>>>>                 get the coarse matrix because the setup is not
>>>>>>>                 done yet (I use a DMKSPSetComputeOperators for
>>>>>>>                 the matrices).
>>>>>>>                 The construction of the matrix free for each
>>>>>>>                 level is here:
>>>>>>>                 https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88
>>>>>>>                 The description of the Stokes preconditioner is
>>>>>>>                 described here :
>>>>>>>                 https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162
>>>>>>>                 I have tried multiple implementations without
>>>>>>>                 success. For me, the start is to add at line 105
>>>>>>>                 something like
>>>>>>>                 KSP coarse;
>>>>>>>                 ierr = PCMGGetCoarseSolve(pc_i,
>>>>>>>                 PC pc_coarse;
>>>>>>>                 ierr = KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
>>>>>>>                 ierr = PCSetType(pc_coarse,
>>>>>>>                 Then, to create the several matrices of the
>>>>>>>                 levels of TELESCOPE, I thought using the same
>>>>>>>                 process as before with DMKSPSetComputeOperators.
>>>>>>>                 But it doesn't work...
>>>>>>>                 Could you tell me how I can make it work ?
>>>>>>>                 Thanks,
>>>>>>>                 Loic
>>>             What most experimenters take for granted before they
>>>             begin their experiments is infinitely more interesting
>>>             than any results to which their experiments lead.
>>>             -- Norbert Wiener
>>>             https://www.cse.buffalo.edu/~knepley/
>>>             <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220517/a2a7240b/attachment-0001.html>
