[petsc-dev] Telescope usage
    Dave May
    dave.mayhem23 at gmail.com
    Tue May 17 05:03:26 CDT 2022
On Tue 17. May 2022 at 11:56, Loic Gouarin <loic.gouarin at polytechnique.edu>
wrote:
> Hi Dave,
> could you explain what you mean by state ?
Ah - by state Matt and I mean any auxiliary data stored in the user context
passed to KSPSetComputeOperators which is required to define your operator
and is distributed. For example, a Vec which is used store coefficients of
your PDE.
> Loic
> Le 17/05/2022 à 11:50, Dave May a écrit :
> Hi Loic,
> Can you confirm if your problem has stored state which needs to be
> repartitioned?
> Thanks,
> Dave
> On Tue 17. May 2022 at 09:07, Loic Gouarin <loic.gouarin at polytechnique.edu>
> wrote:
>> Le 17/05/2022 à 01:43, Dave May a écrit :
>> On Tue, 17 May 2022 at 00:12, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Mon, May 16, 2022 at 9:59 AM Loic Gouarin <
>>> loic.gouarin at polytechnique.edu> wrote:
>>>> Le 16/05/2022 à 21:54, Barry Smith a écrit :
>>>> On May 16, 2022, at 3:50 PM, Loic Gouarin <
>>>> Thanks Barry for your quick reply.
>>>> Le 16/05/2022 à 21:41, Barry Smith a écrit :
>>>>   Loic,
>>>>     From your code it looks like you are using a DM. Is it a DMDA or a
>>>> shell DM? If it is a DMDA then the process is intended to be pretty
>>>> straightforward. PCTELESCOPE should create a new DMDA that has the same
>>>> properties as the coarse grid DMDA but lives on a smaller number of ranks.
>>>> From this you can just provide multiple levels of coarsening of the DMDA to
>>>> produce the smaller multigrid problems.
>>>> It's a DMDA. So what you mean is to take the KSP of PCTELESCOPE, get
>>>> the DM which is the same of the coarse grid and build all the levels as
>>>> previously for the levels of PCTELESCOPE ?
>>>>   Yes, I think you should be able to pull out of the coarse level PC
>>>> (on the subset of ranks) a DM that and then setup coarse levels from that.
>>>> But you need to look at an example that that uses telescope and probably
>>>> even the telescope code itself to see all the details. I don't know them
>>>> anymore.
>>>> I looked at the source code but It didn't help. I will try to explain
>>>> more clearly my experiments to understand what I make wrong and you can
>>>> help more easily.
>>> Hi Loic!
>>> Here is my guess. When TELESCOPE redistributes the coarse grid DMDA, it
>>> creates a new DMDA and copies over all the information it can see. However,
>>> I think you may have state that is attached to the old DMDA that is not
>>> getting redistributed. If this is true, I can help you write a hook that
>>> redistributes that state when TELESCOPE maps between distributions.
>> If you have state you need to propagate between different communicators,
>> you will have to use the telescope type which is internally is referred to
>> as
>> TELESCOPE_COARSEDM
>> To activate this type you need the option
>> -pc_telescope_use_coarse_dm
>> Or to call PCTelescopeSetUseCoarseDM()
>> The assumptions of usng this options are described here
>> https://petsc.org/main/docs/manualpages/PC/PCTelescopeSetUseCoarseDM
>> and source associated with the COARSEDM
>> https://petsc.org/main/src/ksp/pc/impls/telescope/telescope_coarsedm.c.html
>> Using TELESCOPE_COARSEDM you will have access to the hooks Matt is
>> referring to.
>> Thanks Matthew and Dave.
>> I used TELESCOPE_COARSEDM in my previous tests but it tells me that "Zero
>> instances of a coarse DM were found". And indeed, my coarse solver only has
>> the DM on the coarse mesh and not on the fine level with a coarse DM
>> atttached. I think it's because I use DMKSPSetComputeOperators to create
>> the KSP on each level.
>> So for now, I just added
>> KSP coarse;
>> ierr = PCMGGetCoarseSolve(pc_i, &coarse);CHKERRQ(ierr);
>> PC pc_coarse;
>> ierr = KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
>> ierr = PCSetType(pc_coarse, PCTELESCOPE);CHKERRQ(ierr);
>> ierr = PCTelescopeSetUseCoarseDM(pc_coarse, PETSC_TRUE);CHKERRQ(ierr);
>> but it's not enough.
>> Cheers,
>> Loic
>> Cheers,
>> Dave
>>>    Thanks,
>>>      Matt
>>>> Thanks,
>>>> Loic
>>>>   Barry
>>>>    Can you let us know more details of what exactly goes wrong with
>>>> attempts? It is likely straightforward to get things working, perhaps due
>>>> to our unclear documentation.
>>>> I essentially have wrong state or NULL matrices into the PCTELESCOPE.
>>>> Loic
>>>>   Barry
>>>> On May 16, 2022, at 3:28 PM, Loic Gouarin <
>>>> Hello,
>>>> I could have posted my message on the user list but it seems to me that
>>>> it's more in the petsc development part. Don't hesitate to tell me if I'm
>>>> wrong.
>>>> I am developing a code called cafes that studies fluid-particle
>>>> interactions in a Stokes fluid. For that, we implemented the whole solver
>>>> in matrix free on a cartesian grid. The preconditioner is naturally a
>>>> geometrical multigrid for the velocity. The set of matrix free for each
>>>> level is set by hand (I worked with Matthew on this a long time ago now!).
>>>> I would have liked to implement telescope on this part. I started it
>>>> but I didn't get out of it. So I would like to have your help.
>>>> What I tried to do was to describe my classical multigrid up to a level
>>>> N1 and then take the coarse solver and apply the telescope preconditioner
>>>> to it up to a level N2. I don't know if this is the best way but it seemed
>>>> the most intuitive. The problem is that I could not get the coarse matrix
>>>> because the setup is not done yet (I use a DMKSPSetComputeOperators for the
>>>> matrices).
>>>> The construction of the matrix free for each level is here:
>>>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88
>>>> The description of the Stokes preconditioner is described here :
>>>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162
>>>> I have tried multiple implementations without success. For me, the
>>>> start is to add at line 105 something like
>>>> KSP coarse;
>>>> PC pc_coarse;
>>>> Then, to create the several matrices of the levels of TELESCOPE, I
>>>> thought using the same process as before with DMKSPSetComputeOperators. But
>>>> it doesn't work...
>>>> Could you tell me how I can make it work ?
>>>> Thanks,
>>>> Loic
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220517/c5518732/attachment-0001.html>
