[petsc-dev] PETSc future starting as a new design layer that runs on top of PETSc 3?
Jeremy L Thompson jeth8984 at colorado.edu
Tue Jul 26 09:17:07 CDT 2022
I feel like someone has to mention the possibility of Rust.
In libCEED, we've found the FFI to C fairly painless. We made some
improvements on the core C code of libCEED to facilitate Rust error
handling and data ownership.
 From various prototyping we've done in Jed's group, I think the more
complex data ownership used in PETSc (as compared to libCEED) is one of
the more complex issues that would need to be planned out for a Rust
focused interface.
On 7/25/22 15:34, Barry Smith wrote:
>    A  major problem with writing a completely new version of a large
> code base is that one has to start with nothing and slowly build up to
> everything, which can take years. Years in which you need to continue
> to maintain the old version, people want to continue to add
> functionality to the old version, and people want to continue to use
> the old version because the new version doesn't have "the
> functionality the user needs" ready yet.
>   Is there an approach where we can have a new PETSc
> API/language/paradigm but start with a very thin layer on the current
> API so it just works from day one?
>   * to this would seem to require if PETSc future is not in C, there
>     has to be a very, very easy way and low error-prone way to wrap
>     PETSc current to be called from the new language. For example, how
>     petsc4py wraps seems too manual and too error-prone. C++ can
>     easily and low-error prone call C, any other viable candidates?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220726/d103980a/attachment.html>
