[petsc-dev] Kokkos/Crusher perforance
Jed Brown
jed at jedbrown.org
Sat Jan 22 13:11:11 CST 2022
Barry Smith <bsmith at petsc.dev> writes:
>> On Jan 22, 2022, at 12:15 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Barry, when you did the tech reports, did you make an example to reproduce on other architectures? Like, run this one example (it'll run all the benchmarks across different sizes) and then run this script on the output to make all the figures?
> It is documented in https://www.overleaf.com/project/5ff8f7aca589b2f7eb81c579 You may need to dig through the submit scripts etc to find out exactly.
This runs a ton of small jobs and each job doesn't really preload, but instead of loops in job submission scripts, the loops could be inside the C code and it could directly output tabular data. This would run faster and be easier to submit and analyze.
https://gitlab.com/hannah_mairs/summit-performance/-/blob/master/summit-submissions/submit_gpu1.lsf
It would hopefully also avoid writing the size range manually over here in the analysis script where it has to match exactly the job submission.
https://gitlab.com/hannah_mairs/summit-performance/-/blob/master/python/graphs.py#L8-9
We'd make our lives a lot easier understanding new machines if we put into the design of performance studies just a fraction of the kind of thought we put into public library interfaces.
