[petsc-dev] Kokkos/Crusher perforance
    Barry Smith
    bsmith at petsc.dev
    Sat Jan 22 12:50:34 CST 2022
> On Jan 22, 2022, at 12:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
>> as far as streams, does it know to run on the GPU? You don't specify
>> something like -G 1 here for GPUs. I think you just get them all.
> No, this isn't GPU code. BabelStream is a common STREAM suite for different programming models, though I think it doesn't support MPI with GPUs and thus isn't really useful. The code is pretty vanilla.
> https://github.com/UoB-HPC/BabelStream
> It's very similar to "nstream" in Jeff's PRK
> https://github.com/ParRes/Kernels
> Code is vanilla so I'd expect the results to be much like the corresponding Vec operations.
> Barry, when you did the tech reports, did you make an example to reproduce on other architectures? Like, run this one example (it'll run all the benchmarks across different sizes) and then run this script on the output to make all the figures?
   It is documented in https://www.overleaf.com/project/5ff8f7aca589b2f7eb81c579    You may need to dig through the submit scripts etc to find out exactly.
