[petsc-dev] Speeding up building docs
    Patrick Sanan
    patrick.sanan at gmail.com
    Sat Jan 15 00:07:49 CST 2022
Yes, that's a good point - there's no reason to do the copy if we're
already assuming the source is up to date, so we can easily just check if
the destination already has data!
Also, while the build time certainly annoys me as well, it stopped being as
much of a priority to improve because it now happens after the main Sphinx
logic - if the thing you're iterating on is on the .rst pages, you can
examine it before the copies and link fixes are done (though obviously the
classic pages may not exist or be current, and the links may still be
broken, with placeholders in them).
Am Fr., 14. Jan. 2022 um 22:48 Uhr schrieb Barry Smith <bsmith at petsc.dev>:
>   Patrick,
>     Building docs is so much faster now, thanks! But when I get
> Assuming that the classic docs in
> /Users/barrysmith/Src/petsc/doc/_build_classic are current
> it still does
>     Copying classic docs from conf.py
> Copying directory
> /Users/barrysmith/Src/petsc/doc/_build_classic/docs/manualpages to
> /Users/barrysmith/Src/petsc/doc/_build/html/docs/manualpages
> Copying directory /Users/barrysmith/Src/petsc/doc/_build_classic/include
> to /Users/barrysmith/Src/petsc/doc/_build/html/include
> Copying directory /Users/barrysmith/Src/petsc/doc/_build_classic/src to
> /Users/barrysmith/Src/petsc/doc/_build/html/src
>     Fixing relative links from conf.py
>     Adding version to classic man pages, from conf.py
> Would it be possible to rig the dependencies so that the copies and fixes
> are only done when needed, instead of every time?
> Thanks
> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220115/923e7797/attachment.html>
