[petsc-dev] cuda with kokkos-cuda build fail
Mark Adams
mfadams at lbl.gov
Fri Jan 7 13:23:34 CST 2022
And it looks universal:
11:21 nid001544 main= perlmutter:~/petsc$ make
PETSC_ARCH=arch-perlmutter-opt-gcc-kokkos-cuda -f gmakefile test search='
*snes_tutorials-ex19_cuda*'
Using MAKEFLAGS: -- search=snes_tutorials-ex19_cuda
CC arch-perlmutter-opt-gcc-kokkos-cuda/tests/snes/tutorials/ex19.o
CLINKER arch-perlmutter-opt-gcc-kokkos-cuda/tests/snes/tutorials/ex19
TEST
arch-perlmutter-opt-gcc-kokkos-cuda/tests/counts/snes_tutorials-ex19_cuda.counts
# retrying snes_tutorials-ex19_cuda
not ok snes_tutorials-ex19_cuda # Error code: 97
# lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
# [0]PETSC ERROR: --------------------- Error Message
# [0]PETSC ERROR: GPU error
# [0]PETSC ERROR: cuBLAS error 13 (CUBLAS_STATUS_EXECUTION_FAILED)
# [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
# [0]PETSC ERROR: Petsc Development GIT revision: v3.16.3-511-g96172674f3
GIT Date: 2022-01-06 23:44:32 +0000
# [0]PETSC ERROR:
/global/u2/m/madams/petsc/arch-perlmutter-opt-gcc-kokkos-cuda/tests/snes/tutorials/runex19_cuda/../ex19
on a arch-perlmutter-opt-gcc-kokkos-cuda named nid001544 by madams Fri Jan
7 11:22:35 2022
# [0]PETSC ERROR: Configure options --CFLAGS=" -g -DLANDAU_DIM=2
-DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CXXFLAGS=" -g -DLANDAU_DIM=2
-DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CUDAFLAGS="-g -Xcompiler
-rdynamic -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4"
--with-cc=cc --with-cxx=CC --with-fc=ftn --LDFLAGS=-lmpifort_gnu_91
--with-cudac=/global/common/software/nersc/cos1.3/cuda/11.3.0/bin/nvcc
--COPTFLAGS=" -O3" --CXXOPTFLAGS=" -O3" --FOPTFLAGS=" -O3"
--with-debugging=0 --download-metis --download-parmetis --with-cuda=1
--with-cuda-arch=80 --with-mpiexec=srun --with-batch=0 --download-p4est=1
--with-zlib=1 --download-kokkos --download-kokkos-kernels
--with-kokkos-kernels-tpl=0 --with-make-np=8
# [0]PETSC ERROR: #1 VecNorm_SeqCUDA() at
/global/u2/m/madams/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu:994
# [0]PETSC ERROR: #2 VecNorm() at
/global/u2/m/madams/petsc/src/vec/vec/interface/rvector.c:228
# [0]PETSC ERROR: #3 SNESSolve_NEWTONLS() at
/global/u2/m/madams/petsc/src/snes/impls/ls/ls.c:179
# [0]PETSC ERROR: #4 SNESSolve() at
/global/u2/m/madams/petsc/src/snes/interface/snes.c:4810
# [0]PETSC ERROR: #5 main() at
/global/u2/m/madams/petsc/src/snes/tutorials/ex19.c:159
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -check_pointer_intensity 0
# [0]PETSC ERROR: -dm_mat_type aijcusparse
# [0]PETSC ERROR: -dm_vec_type cuda
# [0]PETSC ERROR: -error_output_stdout
# [0]PETSC ERROR: -ksp_type fgmres
# [0]PETSC ERROR: -malloc_dump
# [0]PETSC ERROR: -nox
# [0]PETSC ERROR: -nox_warning
# [0]PETSC ERROR: -pc_type none
# [0]PETSC ERROR: -snes_monitor_short
# [0]PETSC ERROR: -snes_rtol 1.e-5
# [0]PETSC ERROR: -use_gpu_aware_mpi 0
# [0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
# MPICH Notice [Rank 0] [job id 1041592.1] [Fri Jan 7 11:22:36 2022]
[nid001544] - Abort(97) (rank 0 in comm 0): application called
MPI_Abort(MPI_COMM_WORLD, 97) - process 0
# Kokkos::Cuda ERROR: Failed to call Kokkos::Cuda::finalize()
# srun: error: nid001544: task 0: Exited with exit code 97
# srun: launch/slurm: _step_signal: Terminating StepId=1041592.1
ok snes_tutorials-ex19_cuda # SKIP Command failed so no diff
On Fri, Jan 7, 2022 at 2:20 PM Mark Adams <mfadams at lbl.gov> wrote:
> Well, this sure looks like it is deterministic:
> 11:00 130 nid002645 main= perlmutter:~/petsc$ make
> search='ts_utils_dmplexlandau_tutorials-ex1_cuda'
> Using MAKEFLAGS: -- search=ts_utils_dmplexlandau_tutorials-ex1_cuda
> CC
> arch-perlmutter-opt-gcc-kokkos-cuda/tests/ts/utils/dmplexlandau/tutorials/ex1.o
> CLINKER
> TEST
> arch-perlmutter-opt-gcc-kokkos-cuda/tests/counts/ts_utils_dmplexlandau_tutorials-ex1_cuda.counts
> # retrying ts_utils_dmplexlandau_tutorials-ex1_cuda
> not ok ts_utils_dmplexlandau_tutorials-ex1_cuda # Error code: 97
> # masses: e= 9.109e-31; ions in proton mass units: 2.000e+00
> 4.000e+00 ...
> # charges: e=-1.602e-19; charges in elementary units: 1.000e+00
> 1.800e+01
> # n: e: 1.000e+00 i: 1.000e+00
> 1.000e-05
> # thermal T (K): e= 5.802e+07 i= 5.802e+07 5.802e+06. v_0= 2.965e+07 (
> 9.892e-02c) n_0= 1.000e+20 t_0= 6.470e-05, classical, Intuitive, 1 batched
> # Domain radius (AMR levels) grid 0: 5. (2) , 1: 8.252e-02 (1)
> # 0) FormLandau 352 IPs, 22 cells total, Nb=16, Nq=16, dim=2, Tab: Nb=16
> Nf=3 Np=16 cdim=2 N=324
> # 0) species-0: charge density= -1.6024538233648e+01 z-momentum=
> -1.7133689250463e-19 energy= 1.2009868166183e+05
> # 0) species-1: charge density= 1.6068752193414e+01 z-momentum=
> -5.3757901114069e-19 energy= 1.1752123333205e+05
> # 0) species-2: charge density= 2.7152642046328e-04 z-momentum=
> 3.4016005887213e-21 energy= 1.1701658725855e+00
> # 0) Total: charge density= 4.4485486187274e-02, momentum=
> -7.0551430305659e-19, energy= 2.3762108515975e+05 (m_i[0]/m_e = 3670.94,
> 14 cells on electron grid)
> # 0 TS dt 0.1 time 0.
> # [0]PETSC ERROR:
> /global/u2/m/madams/petsc/arch-perlmutter-opt-gcc-kokkos-cuda/tests/ts/utils/dmplexlandau/tutorials/runex1_cuda/../ex1
> on a arch-perlmutter-opt-gcc-kokkos-cuda named nid002645 by madams Fri Jan
> 7 11:15:42 2022
> # [0]PETSC ERROR: #5 TSStep_ARKIMEX() at
> /global/u2/m/madams/petsc/src/ts/impls/arkimex/arkimex.c:845
> # [0]PETSC ERROR: #6 TSStep() at
> /global/u2/m/madams/petsc/src/ts/interface/ts.c:3572
> # [0]PETSC ERROR: #7 TSSolve() at
> /global/u2/m/madams/petsc/src/ts/interface/ts.c:3971
> # [0]PETSC ERROR: #8 main() at
> /global/u2/m/madams/petsc/src/ts/utils/dmplexlandau/tutorials/ex1.c:45
> # [0]PETSC ERROR: -dm_landau_amr_levels_max 2,1
> # [0]PETSC ERROR: -dm_landau_device_type cuda
> # [0]PETSC ERROR: -dm_landau_ion_charges 1,18
> On Fri, Jan 7, 2022 at 1:52 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Fri, Jan 7, 2022 at 11:17 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> These are cuda/cusparse tests. The Kokkos versions are fine and cusparse
>>> w/o a Kokkos build is fine.
>>> I do have some #ifdefs in the code. Maybe something snuck into the
>>> #ifdef KOKKOS, but I can't imagine what that could even be.
>>> I have had problems with very large "cuda" jobs (on Summit with 21 MPI
>>> processes per GPU) running out of "resources" with a Kokkos build, that
>>> went away with a pure CUDA build (ie, w/o Kokkos), but these are tiny tests.
>> If Kokkos is initialized on MPI ranks, then each rank will consume
>> resources on GPU.
>>> I will try it again.
>>> Thanks,
>>> On Fri, Jan 7, 2022 at 12:06 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> It failed when you did not even pass any vec/mat kokkos options? It
>>>> does not make sense and you need to double check that.
>>>> --Junchao Zhang
>>>> On Thu, Jan 6, 2022 at 9:33 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> I seem to have a regression with using aijcusprase in a kokkos build.
>>>>> It's OK with a straight CUDA build.
>>>>> shooting.
>>>>> v3.16.3-511-g96172674f3 GIT Date: 2022-01-06 23:44:32 +0000
>>>>> # [0]PETSC ERROR:
>>>>> /global/u2/m/madams/petsc_install/petsc/arch-perlmutter-opt-gcc-kokkos-cuda/tests/ts/utils/dmplexlandau/tutorials/runex1_cuda/../ex1
>>>>> on a arch-perlmutter-opt-gcc-kokkos-cuda named nid003188 by madams Thu Jan
>>>>> 6 19:29:06 2022
>>>>> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc
>>>>> /global/u2/m/madams/petsc_install/petsc/src/vec/vec/impls/seq/seqcuda/
>>>>> veccuda2.cu:994
>>>>> /global/u2/m/madams/petsc_install/petsc/src/vec/vec/interface/rvector.c:228
>>>>> /global/u2/m/madams/petsc_install/petsc/src/snes/impls/ls/ls.c:179
>>>>> /global/u2/m/madams/petsc_install/petsc/src/snes/interface/snes.c:4810
>>>>> /global/u2/m/madams/petsc_install/petsc/src/ts/impls/arkimex/arkimex.c:845
>>>>> /global/u2/m/madams/petsc_install/petsc/src/ts/interface/ts.c:3572
>>>>> /global/u2/m/madams/petsc_install/petsc/src/ts/interface/ts.c:3971
>>>>> /global/u2/m/madams/petsc_install/petsc/src/ts/utils/dmplexlandau/tutorials/ex1.c:45
>>>>> # [0]PETSC ERROR: -dm_landau_ion_masses 2,4
>>>>> # [0]PETSC ERROR: -dm_landau_n 1.00018,1,1e-5
>>>>> # [0]PETSC ERROR: -dm_landau_n_0 1e20
>>>>> # [0]PETSC ERROR: -dm_landau_num_species_grid 1,2
>>>>> # [0]PETSC ERROR: -dm_landau_thermal_temps 5,5,.5
>>>>> # [0]PETSC ERROR: -dm_landau_type p4est
>>>>> # [0]PETSC ERROR: -dm_preallocate_only false
>>>>> # [0]PETSC ERROR: -ksp_type preonly
>>>>> # [0]PETSC ERROR: -mat_cusparse_use_cpu_solve
>>>>> # [0]PETSC ERROR: -pc_type lu
>>>>> # [0]PETSC ERROR: -petscspace_degree 3
>>>>> # [0]PETSC ERROR: -petscspace_poly_tensor 1
>>>>> # [0]PETSC ERROR: -snes_converged_reason
>>>>> # [0]PETSC ERROR: -snes_rtol 1.e-14
>>>>> # [0]PETSC ERROR: -snes_stol 1.e-14
>>>>> # [0]PETSC ERROR: -ts_adapt_clip .5,1.25
>>>>> # [0]PETSC ERROR: -ts_adapt_scale_solve_failed 0.75
>>>>> # [0]PETSC ERROR: -ts_adapt_time_step_increase_delay 5
>>>>> # [0]PETSC ERROR: -ts_arkimex_type 1bee
>>>>> # [0]PETSC ERROR: -ts_dt 1.e-1
>>>>> # [0]PETSC ERROR: -ts_max_snes_failures -1
>>>>> # [0]PETSC ERROR: -ts_max_steps 1
>>>>> # [0]PETSC ERROR: -ts_max_time 1
>>>>> # [0]PETSC ERROR: -ts_monitor
>>>>> # [0]PETSC ERROR: -ts_rtol 1e-1
>>>>> # [0]PETSC ERROR: -ts_type arkimex
>>>>> entire error message to petsc-maint at mcs.anl.gov----------
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220107/2daaf9ee/attachment-0001.html>
