[petsc-dev] cuda with kokkos-cuda build fail
Junchao Zhang junchao.zhang at gmail.com
Fri Jan 7 12:52:02 CST 2022
On Fri, Jan 7, 2022 at 11:17 AM Mark Adams <mfadams at lbl.gov> wrote:
> These are cuda/cusparse tests. The Kokkos versions are fine and cusparse
> w/o a Kokkos build is fine.
> I do have some #ifdefs in the code. Maybe something snuck into the #ifdef
> KOKKOS, but I can't imagine what that could even be.
> I have had problems with very large "cuda" jobs (on Summit with 21 MPI
> processes per GPU) running out of "resources" with a Kokkos build, that
> went away with a pure CUDA build (ie, w/o Kokkos), but these are tiny tests.
If Kokkos is initialized on MPI ranks, then each rank will consume
resources on GPU.
> I will try it again.
> Thanks,
> On Fri, Jan 7, 2022 at 12:06 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> It failed when you did not even pass any vec/mat kokkos options?  It does
>> not make sense and you need to double check that.
>> --Junchao Zhang
>> On Thu, Jan 6, 2022 at 9:33 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> I seem to have a regression with using aijcusprase in a kokkos build.
>>> It's OK with a straight CUDA build.
>>> # [0]PETSC ERROR: --------------------- Error Message
>>> # [0]PETSC ERROR: GPU error
>>> # [0]PETSC ERROR: cuBLAS error 13 (CUBLAS_STATUS_EXECUTION_FAILED)
>>> # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>> shooting.
>>> # [0]PETSC ERROR: Petsc Development GIT revision:
>>> v3.16.3-511-g96172674f3  GIT Date: 2022-01-06 23:44:32 +0000
>>> # [0]PETSC ERROR:
>>> /global/u2/m/madams/petsc_install/petsc/arch-perlmutter-opt-gcc-kokkos-cuda/tests/ts/utils/dmplexlandau/tutorials/runex1_cuda/../ex1
>>> on a arch-perlmutter-opt-gcc-kokkos-cuda named nid003188 by madams Thu Jan
>>>  6 19:29:06 2022
>>> # [0]PETSC ERROR: Configure options --CFLAGS="   -g -DLANDAU_DIM=2
>>> -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CXXFLAGS=" -g -DLANDAU_DIM=2
>>> -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CUDAFLAGS="-g -Xcompiler
>>> -rdynamic -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4"
>>> --with-cc=cc --with-cxx=CC --with-fc=ftn --LDFLAGS=-lmpifort_gnu_91
>>> --with-cudac=/global/common/software/nersc/cos1.3/cuda/11.3.0/bin/nvcc
>>> --COPTFLAGS="   -O3" --CXXOPTFLAGS=" -O3" --FOPTFLAGS="   -O3"
>>> --with-debugging=0 --download-metis --download-parmetis --with-cuda=1
>>> --with-cuda-arch=80 --with-mpiexec=srun --with-batch=0 --download-p4est=1
>>> --with-zlib=1 --download-kokkos --download-kokkos-kernels
>>> --with-kokkos-kernels-tpl=0 --with-make-np=8
>>> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc
>>> PETSC_ARCH=arch-perlmutter-opt-gcc-kokkos-cuda
>>> # [0]PETSC ERROR: #1 VecNorm_SeqCUDA() at
>>> /global/u2/m/madams/petsc_install/petsc/src/vec/vec/impls/seq/seqcuda/
>>> veccuda2.cu:994
>>> # [0]PETSC ERROR: #2 VecNorm() at
>>> /global/u2/m/madams/petsc_install/petsc/src/vec/vec/interface/rvector.c:228
>>> # [0]PETSC ERROR: #3 SNESSolve_NEWTONLS() at
>>> /global/u2/m/madams/petsc_install/petsc/src/snes/impls/ls/ls.c:179
>>> # [0]PETSC ERROR: #4 SNESSolve() at
>>> /global/u2/m/madams/petsc_install/petsc/src/snes/interface/snes.c:4810
>>> # [0]PETSC ERROR: #5 TSStep_ARKIMEX() at
>>> /global/u2/m/madams/petsc_install/petsc/src/ts/impls/arkimex/arkimex.c:845
>>> # [0]PETSC ERROR: #6 TSStep() at
>>> /global/u2/m/madams/petsc_install/petsc/src/ts/interface/ts.c:3572
>>> # [0]PETSC ERROR: #7 TSSolve() at
>>> /global/u2/m/madams/petsc_install/petsc/src/ts/interface/ts.c:3971
>>> # [0]PETSC ERROR: #8 main() at
>>> /global/u2/m/madams/petsc_install/petsc/src/ts/utils/dmplexlandau/tutorials/ex1.c:45
>>> # [0]PETSC ERROR: PETSc Option Table entries:
>>> # [0]PETSC ERROR: -check_pointer_intensity 0
>>> # [0]PETSC ERROR: -dm_landau_amr_levels_max 2,1
>>> # [0]PETSC ERROR: -dm_landau_device_type cuda
>>> # [0]PETSC ERROR: -dm_landau_ion_charges 1,18
>>> # [0]PETSC ERROR: -dm_landau_ion_masses 2,4
>>> # [0]PETSC ERROR: -dm_landau_n 1.00018,1,1e-5
>>> # [0]PETSC ERROR: -dm_landau_n_0 1e20
>>> # [0]PETSC ERROR: -dm_landau_num_species_grid 1,2
>>> # [0]PETSC ERROR: -dm_landau_thermal_temps 5,5,.5
>>> # [0]PETSC ERROR: -dm_landau_type p4est
>>> # [0]PETSC ERROR: -dm_mat_type aijcusparse
>>> # [0]PETSC ERROR: -dm_preallocate_only false
>>> # [0]PETSC ERROR: -dm_vec_type cuda
>>> # [0]PETSC ERROR: -error_output_stdout
>>> # [0]PETSC ERROR: -ksp_type preonly
>>> # [0]PETSC ERROR: -malloc_dump
>>> # [0]PETSC ERROR: -mat_cusparse_use_cpu_solve
>>> # [0]PETSC ERROR: -nox
>>> # [0]PETSC ERROR: -nox_warning
>>> # [0]PETSC ERROR: -pc_type lu
>>> # [0]PETSC ERROR: -petscspace_degree 3
>>> # [0]PETSC ERROR: -petscspace_poly_tensor 1
>>> # [0]PETSC ERROR: -snes_converged_reason
>>> # [0]PETSC ERROR: -snes_monitor
>>> # [0]PETSC ERROR: -snes_rtol 1.e-14
>>> # [0]PETSC ERROR: -snes_stol 1.e-14
>>> # [0]PETSC ERROR: -ts_adapt_clip .5,1.25
>>> # [0]PETSC ERROR: -ts_adapt_scale_solve_failed 0.75
>>> # [0]PETSC ERROR: -ts_adapt_time_step_increase_delay 5
>>> # [0]PETSC ERROR: -ts_arkimex_type 1bee
>>> # [0]PETSC ERROR: -ts_dt 1.e-1
>>> # [0]PETSC ERROR: -ts_max_snes_failures -1
>>> # [0]PETSC ERROR: -ts_max_steps 1
>>> # [0]PETSC ERROR: -ts_max_time 1
>>> # [0]PETSC ERROR: -ts_monitor
>>> # [0]PETSC ERROR: -ts_rtol 1e-1
>>> # [0]PETSC ERROR: -ts_type arkimex
>>> # [0]PETSC ERROR: -use_gpu_aware_mpi 0
>>> # [0]PETSC ERROR: ----------------End of Error Message -------send
>>> entire error message to petsc-maint at mcs.anl.gov----------
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220107/a4534ebf/attachment.html>
