[petsc-dev] proposed minor PetscPartitioner changes
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Aug 31 16:49:46 CDT 2022
Thanks Barry, it works fine! :)
Eric
On 2022-08-31 16:28, Barry Smith wrote:
> You can use PetscObjectSetOptionsPrefix((PetscObject) partitioner,...
>> On Aug 31, 2022, at 10:21 AM, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca> wrote:
>> Anyone have something to say about this?
>> Thanks,
>> Eric
>> On 2022-07-06 22:32, Eric Chamberland wrote:
>>> Hi,
>>> I was looking for PetscPartitionerSetOptionsPrefix function, but
>>> only found this post mentioning it.
>>> I was "blindly" coding with in mind the possibility to manage
>>> different options for partitioning different meshes for the same
>>> global computation, so I thought each PetscPartitionner would be
>>> able to have his own prefixe...
>>> Do you think it is feasible to add this feature?...
>>> ...or does it exist under another name?
>>> Thanks,
>>> Eric
>>> On 2017-11-06 08:09, Vaclav Hapla wrote:
>>>> Hello
>>>> The whole PetscPartitioner class sources are part of src/dm/impls/plex/plexpartition.c, mixed together with some DMPlex* functions.
>>>> If you don't mind, I would move the PetscPartitioner* stuff into the separate file petscpartitioner.c
>>>> (in future, it could be even moved to a separate directory).
>>>> I would also like to
>>>> * add PetscPartitioner{Add,Set,Get}OptionsPrefix,
>>>> * create the partitioner lazily in DMPlexGetPartitioner, followed by PetscObjectIncrementTabLevel, PetscLogObjectParent and PetscPartitionerSetOptionsPrefix calls,
>>>> * edit src/dm/impls/plex/examples/tutorials/ex5.c so that it calls DMSetFromOptions right after DMPlexCreateFromFile, in order to make the partitioner changeable from options.
>>>> Do you have anything against?
>>>> Vaclav
>>> Eric Chamberland, ing., M. Ing
>>> Professionnel de recherche
>>> GIREF/Université Laval
>>> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220831/2f733c40/attachment.html>
