[petsc-dev] proposed minor PetscPartitioner changes
Barry Smith bsmith at petsc.dev
Wed Aug 31 09:28:15 CDT 2022
  You  can use PetscObjectSetOptionsPrefix((PetscObject) partitioner,...
> On Aug 31, 2022, at 10:21 AM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Anyone have something to say about this?
> Thanks,
> Eric
> On 2022-07-06 22:32, Eric Chamberland wrote:
>> Hi,
>> I was looking for PetscPartitionerSetOptionsPrefix function, but only found this post mentioning it.
>> I was "blindly" coding with in mind the possibility to manage different options for partitioning different meshes for the same global computation, so I thought each PetscPartitionner would be able to have his own prefixe...
>> Do you think it is feasible to add this feature?...
>> ...or does it exist under another name?
>> Thanks,
>> Eric
>> On 2017-11-06 08:09, Vaclav Hapla wrote:
>>> Hello
>>> The whole PetscPartitioner class sources are part of src/dm/impls/plex/plexpartition.c, mixed together with some DMPlex* functions.
>>> If you don't mind, I would move the PetscPartitioner* stuff into the separate file petscpartitioner.c
>>> (in future, it could be even moved to a separate directory).
>>> I would also like to
>>> * add PetscPartitioner{Add,Set,Get}OptionsPrefix,
>>> * create the partitioner lazily in DMPlexGetPartitioner, followed by PetscObjectIncrementTabLevel, PetscLogObjectParent and PetscPartitionerSetOptionsPrefix calls,
>>> * edit src/dm/impls/plex/examples/tutorials/ex5.c so that it calls DMSetFromOptions right after DMPlexCreateFromFile, in order to make the partitioner changeable from options.
>>> Do you have anything against?
>>> Vaclav
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220831/61848006/attachment.html>
