[petsc-dev] Reminder: You may want to get some of , your MR merged before the global clang-format reformatting later this week
Barry Smith
bsmith at petsc.dev
Mon Aug 15 10:19:02 CDT 2022
Reminder: You may want to get some of your MR merged before the global clang-format reformatting later this week. If so you should be contacting reviewers etc to get it merged soon.
Barry
Note: if your MR is new code (or new distinct chunks of code in current files with little inline changes to the current code) then a rebase should be straightforward so there is little need to get your MR before the reformatting.
