[petsc-dev] test harness requires case independent
Scott Kruger kruger at txcorp.com
Fri Apr 29 16:57:38 CDT 2022
https://gitlab.com/petsc/petsc/-/merge_requests/5189
On 2022-04-27 14:33, Barry Smith did write:
>   Scott,
>   Could the test harness search for requires be made case independent?
> $ make -f gmakefile.test test query='requires' queryval='*superlu_dist*'
> Using MAKEFLAGS: -- queryval=*superlu_dist* query=requires
>      CLINKER arch-superlu_dist-single/tests/ksp/ksp/tests/ex17
>         TEST arch-superlu_dist-single/tests/counts/ksp_ksp_tests-ex17_superlu_dist.counts
>  ok ksp_ksp_tests-ex17_superlu_dist
> $ make -f gmakefile.test test query='requires' queryval='*SuperLU_DIST*'
> Using MAKEFLAGS: -- queryval=*SuperLU_DIST* query=requires
> # No test results in  ./arch-superlu_dist-single/tests/counts
> I looked query_test.py and could not see where the queryval comes from
> Thanks
Scott Kruger
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
